Question about MusicLab BearShare
Remove Memory don't want it!
  • MusicLab Master
  • 27,725 Answers
You should always remove and uninstall programs from your PC that you are not using.
It could be beneficial to your computer's productivity and functioning to free up space.
You run the risk of running out of space on your computer if you add too many programs without uninstalling some.
It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs."
Click "Control Panel" and "Programs" and "Programs and Features."
Browse the list of programs on your computer and select one that you want to remove.
Click "Uninstall."
You may be prompted for permission from the administrator to remove the program.
Enter the administrator password or confirmation if necessary.
Check the properties of the program if it is not listed in "Programs."
You can do this by right-clicking on the program desktop icon and selecting "Properties."
Check to see if the program is compatible with the version of Windows that you are using.
Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program.
Type "Regedt32" in the box and click "OK."
Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab.
Click "Desktop" on the "Export Registry File" dialog box.
Type "Uninstall" in the "File Name" box and select "Save."
The left panel of the Registry Editor will display the programs that are currently installed.
Right-click the key in the left panel of the Registry Editor window.
Click "Delete."
Click "Yes" when you are asked to confirm deletion of the program.
Click the "File" menu and select "Exit."
This will exit the Registry Editor.
Click "Start" and "Control Panel" and click "Add or Remove Programs."
Confirm that the program is no longer listed here.
also
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Posted on Apr 23, 2013
Remove the internal memory card
You don't need to remove the internal memory. Simply insert the memory stick, and the camera will store new images and videos to the stick instead of the internal memory.
Jul 24, 2012 | Sony Cameras
How do I remove the internal memory card
Jul 24, 2012 | Sony Cyber-shot Dsc-w610 14.1MP Camera...
Flash bios
You don't want to mess with flashing the bios unless you really know what you're doing.
Also the fact that you don't have a cd drive is another problem in crisis moments like this. Never, Never buy a computer without a cd drive because one day it's going to croak and you'll need the drive.
If you had a cd drive or can somehow get a usb flash drive that you could boot from then you could try the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Also check your memory. It could be your memory chips or one of the memory slots.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 03, 2012 | Computers & Internet
98 gmc safari. Starts sometimes and doesn't other times. Fuel pump tests fine, new fuel filter and crankshaft sensor. Can't afford to keep doing process of elimination.
Check battery cables at battery may be loose or corroded don't disconnect unless memory is maintained always remove neg first and don't reconnect until pos is connected and tight
Apr 02, 2012 | GMC Safari Cars & Trucks
Camera model: panasonic FS3 Lumix cannot remove memory card. know how to remove battery. memory card seems stuck or I don't know the trick to remove
Turn the camera off first.
To remove the memory card you have to push it down a bit, you may hear a little 'click' and as you let go the card will pop up a bit.
Then you can pull it out.
Let me know. Thanks.
Jun 16, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
How do I install the extra memory under the keyboard for a ThinkPad R51 Series (Type 1830)? Which screws on the bottom do I take out? They are numbered 1, 2, 3, 4, etc. in groups. I am sure I don't...
You can find the Hardware and Maintenance Manual here, which gives all the details on removing the keyboard. But this model ships with the standard memory under the keyboard (in a single DIMM socket). Optional memory (again, just a single available socket) is installed from the bottom of the computer. You don't need to remove the keyboard, just loosen one screw that secures the cover over the memory socket. Page 71 in the manual shows the location.
Jun 08, 2011 | IBM ThinkPad R51 1830 (1830AHU) PC...
Can't read any the games from my memory can't open videos
Hi there Jojit.
You don't mention if you have a CFW or the OFW (original from S0ny). If you have the CFW, you should be able to open Homebrew games (that's the term). If you have a CFW and still you cannot open Homebrew games as well as videos, there should be something wrong with your Memory Stick or your CFW.
Try this;
1. Turn off you PSP 2. Remove your Memory Stick and put it back after 10 seconds 3. Put it back and turn your PSP back on
If this doesn't solve your problem, try reformatting your MemStick. Of course, you need to back up all your CSO and ISO files to your PC including your p0rns (eh, videos I mean). LOL
If reformatting doesn't work, try reinstalling your CFW. Get back to me if the first solution don't work and I'll guide you on re-installing your CFW...
Jun 07, 2011 | Sony PlayStation Portable Slim Black...
I have forgot my phone lock password.
Hello.
Don't Worry just Dial this code on your Dial-screen.
*2767*3855#
Note: Don't forget to remove your sim and memory card before dialing this number. It'll reset all your factory settings.
Good-luck.
Apr 25, 2011 | Samsung Star GT-S5233 Cell Phone
I seem to have a problim with my samsung star does not alow me to use mxit plz help so that i can format phone and start fresh
*2767*3855#
Good-luck buddy :)
Apr 24, 2011 | Samsung Star GT-S5233 Cell Phone
I HAVE FORGET MY PRIVACY PASSWORD (DEFENETLY IT IS NUMERIC) HOW CAN I GET DEFAULT
Dude,
I have the same phone and I have solved my problem.
*2767*3855#
Good-luck buddy :)
Apr 23, 2011 | Samsung Star GT-S5233 Cell Phone
Computers & Internet Logo
29 people viewed this question
Top MusicLab Computers & Internet Experts
David Payne
David Payne
Are you a MusicLab Computer and Internet Expert? Answer questions, earn points and help others
