Question about Kitchen Ranges
Kenmore cook top model 790.46789900 replace glass door front
catriver
  • 878 Answers
SOURCE: Jennair cook top
Replacing this top is not too difficult. It is secured by four screws on each side. You might have to remove some of the flanging in the back to pull it off. Make sure to unplug the the unit. I would think that the top might be pricy, but if you take your time replacing it should be no problem.
Posted on May 03, 2006
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Posted on Jul 21, 2007
philbran
  • 242 Answers
SOURCE: Glass cook top has cracked ...
They are expensive but not very hard to change if your carefull. They are about 300-400 on the norm , You may be able to get a new oven on sale for that much ,its up to you. Check with sears parts first. good luck
Posted on Dec 30, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
smartr10U
  • 1305 Answers
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Posted on Jun 06, 2009
The rarely-used back right burner on my glass top GE electric range doesn't work, but the rest of the burners and the oven seem to be working just fine. Is this something I can fix myself, or do I need to...
Open the oven door and look for screws that hold the cook top down. Take those out and the cook top lifts off from the front. Make sure that you unplug it first. Then you can see the coil that is not heating. IT could be the wires, connector or the coil itself that is bad.
Sep 27, 2013 | Kenmore 95592 / 95594 / 95595 / 95599...
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
I need to replace the stainless skin on my freeze
You will most likely need new drawer unit Warner's Stellian in Saint Paul, MN can help. For cleaning DeBruce Polish is the best.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Jan 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I want to change from a white door panel to a stainless steel front on dishwasher. kenmore model 3 16374300 . Where do I order the front.?
Warner's Stellian in Saint Paul can help for exchange. For cleaning stainless steel we reccommend DeBruce Polish. The "green cleaner" DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more.
Dec 13, 2009 | Kenmore 24 in. 15173 Stainless Steel...
Change door from black glass to stainless
Warner's Stellian in St. Paul, MN for replacement. For cleaning DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Dec 01, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Kenmore ultra bake cook top indicator light
is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Apr 09, 2008 | Kenmore 92022 / 92024 / 92025 / 92029...
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
Unplug the cook top and leave the elements in place.
Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
Remove the surface element assembly leaving all the elements wired together.
Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Lower the new cook top into place and secure with screws.
Good luck and I hope this helps.
Apr 06, 2008 | Kitchen Ranges
Kitchen Ranges Logo
19 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
