Question about LG LSC26905TT Side by Side Refrigerator
Makes ice very slowly to none...
I just bought last yrs lg model side by side refrigerator and it makes ice tho very slowly. it can't keep up with our usage. not even close. I can't find a switch that makes it go faster or slower. please advise...
  • Anonymous Apr 14, 2009
    low water pressure and ice only makes four cubes at a time
  • 478 Answers
You need to turn the freezer side to a cole=der setting to allow ice to freeze faster.
Posted on Mar 12, 2009
Water and icemaker stopped working
First, make sure you have water going into the refrigerator. Then check the one in two out solenoid controlled water valve (first place the water line connects). If you put a voltmeter on the solenoid controller, you should see a voltage at the solenoid. If you do, then replace the solenoid controlled water valve, if not then follow the electrical line back and see where you lose the signal.
Feb 03, 2012 | LG LRSC-26922 Side by Side Refrigerator
I have a 6yrs old PSS26SGPASS GE side-by-side refrigerator that works perfectly, except for the last week or so, it started to make a constant whining noise that goes crescendo (increasingly) to a higher...
I would not call a Technician out because it will cost you too much money that you can put aside for a good refrigerator that does not have all of the electronic gadgets that keep it running GE runs behind LG with their great looks. But they both have costly failures when it come to quality electronic controls. I really hate to be honest. Wait that is what you want right? The truth is you can buy a better quality refrigerator by purchasing one that has no electronic control boards. Simple defrost timers will last 3 times longer and the pain of paying a technician to come switch your motherboard out and leave in 15 minutes with $500.00 dollars is just too much guilt for me to carry to lie
to you, Good Luck, Sea Breeze
May 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side by side GS5SHAXN. Ice maker slowly died.
Hi agcruiser;
Have your change your water filter lately?
If not try that, as it may be starting to block up a little.
Another problem could be the water inlet valve(Ice Side) situated at bottom of fridge, that could be starting to wear (Can interchange with water side inlet valve). Yes there are 2- 1 for ice and 1 for water
The Whirlpools Ice Michine set up is very easy, and runs by a mechanical system, they can be tested (Use a qualified tech).
Cheers hope this helps
Mar 29, 2010 | Whirlpool GS5SHAXN Side by Side...
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
I am looking for a reliable refrigerator that will last for $3,000.00 or less. What brand(s) would you recommend?
I have had great service from my Hotpoints that are realy Ge. They Are made in, In. USA
I have 5 working know. 1 is 15 yrs, 3 that are 5 yrs old, And a 1 year old. I clean under them with a vacuum and a brush every Labor Day. Because its easy for me to keep track of it.
hope this helps you.
Sawdust
Aug 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
LG LSC26905TT Side by Side Refrigerator Logo
175 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
