Question about Home
Breaker pops so no power to tub - Home
  • 717 Answers
When does the breaker trip? when you turn on the motor?
Rod
US Parts Center
888-521-6183
Posted on Apr 25, 2013
My hot tub trips the GFCI. THe GFCI holds when I disconnect the wires running into the hot tub. I have disconnected EVERYTHING from the circuit board including the heater and the GFCI still trips.
Sounds like wet or bad wiring somewhere but u should do a visual inspection of all the wires & connections first then through process of elimination. Turn off breaker disconnect all wires and connect one wire then turn breaker on & if it dosent pop the. Turn it off and connect one more wire and turn the breaker on & continue until you get the breaker to pop and the last wire or board u just connected is your problem & go from there.
Feb 14, 2016 | Pool & Spa
My spa depot hot tub keeps popping the breaker
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/How-to-wire-GFCI.html
What type breaker?
GFCI or ordinary heat-rated breaker?
Do NOT use two GFCIs on same circuit.
Spa needs GFCI to protect people while immersed in water.
You might have dangerous short, or leaking element, bad switch, bad wiring, bad electrical connection, or undersized wire and breaker.
If breaker is undersized for load, it can get loose on the busbar and then start arcing, and then tripping. Use nose to smell for burning. Feel breakers to see if they are warm. Move wire to different same-size breaker.
Mar 18, 2013 | Pool & Spa
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
My hydropool spa is tripping the circuit breaker. I moved my hottub off the deck onto a concrete pad next to the deck last summer. No problems, then over the first winter I went out one day and the...
it sounds to me like your hot tub has bugs take the control panel apart and clean the bugs out of it. if you have ants in the area they will get into the controls and cause it to trip out. i had similar problem with apump until i found the ants
May 19, 2011 | Heating & Cooling
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Jacuzzi hot tub, aero select. pops circuit breaker as soon as switch is thrown. I disconected both motors and panel. still blows. Unit is about 8 Years old. Is there anywhere I can get a schmatic or any...
Your Jacuzzi should be connected to a large GFI breaker. If it pops as soon as you turn something on, there is an imbalance between the legs supplying the power to your device. When my (small "J") jacuzzi (at about age 15) did this, I discovered a small leak that had dripped onto the circuit board and had left a deposit causing a "short". I was able to clean the deposit off of the board physically, I fixed the leak and return my tub to service.
The GFI is very sensitive and for good reason. It protects you from dangerous electric voltages, even though the danger is low.
Oct 04, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
How to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Dec 01, 2008 | Pool & Spa
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
