Question about Mitsubishi VS-60611 60" Rear Projection Television
How do I clean lenses on vs-6016
How do I get to & clean lenses on my vs-6016?
    Top Expert:
  • Mitsubishi Master
  • 74,198 Answers
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy. Procedure to clean lenses are described in detail with illustrations. http://electronicshelponline.blogspot.com/
Posted on Apr 23, 2013
5069-6016 no sound
Is this a powered sub that is not plugged in or connected to a power source?
Jan 26, 2013 | HP Harman Kardon Subwoofer Sub Woofer...
How do I get in there safely to clean the mirror?? what do i unscrew first etc.. it still working just fine but the color is going after 15 years and i need to clean the inside.
Hello.
I would not recommend you to touch the mirror. It is hanged sort of reflection surface facing down so it is not real dust collector. You can clean lenses of your CRT tubes (red, green and blue) to improve your picture. Just remove rear cover taking out black and golden screws and you will see dusty lenses right away in the middle of the TV. Use DRY "Bounty" paper towels to remove dust from lenses, don't wet it with any solutions or it will leave film on optics. Just in circular motion move dust to the black plastic edges of lenses. Don't worry about some specs of dust that inevitable will be left behind - they will not affect image at all like thick layer of dust do.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi VS-6041 60" Rear Projection...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
I use to work for sharp manufacturing in memphis, and was told i am suppose to have mineral oil in my color guns of my mitsubishi vs-5043,and would need to add and or replace it every couple of years for...
there is a optic coupling between the tubes and the lenses
it however is not mineral oil
and the fluid that is between the lenses is poisenus
so be careful how its handled
its a glycol base mixture and it doesnt have to be changed every couple years
some brands do seem to have a problem with it but Mitsubishi did not
cleaning the mirror and lenses of course will help give the best picture
i have never changed the fluid in a Mtsubishi unless the tube was leaking
its not recomended
Oct 28, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Spot on my lense and it shows up on my photos.
I doubt it would be a good idea to try to get in there and get rid of the spot yourself.
If it does not affect your photos significantly then leave it be or if you feel you must, have a a professional clean it. ($$$$). Weigh the cost vs. leaving it alone.
Jun 20, 2009 | Kodak EasyShare Z650 Digital Camera
Screen removal from vs45va2
If you want to clean the projection lenses, you do not want to remove the cover screen to get there. That is the hard way, but you should be an experienced technician to do this correctly. Why do you think that the lenses need to be cleaned? What are you seeing on the screen to make you think that the lens needs cleaning?
Nov 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
