Question about Mitsubishi VS-60611 60" Rear Projection Television
How do I clean lens on Vs-6016
How do I get to lens and clean them?
How do I clean lenses on vs-6016
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy. Procedure to clean lenses are described in detail with illustrations. http://electronicshelponline.blogspot.com/
Apr 22, 2013 | Mitsubishi VS-60611 60" Rear Projection...
5069-6016 no sound
Is this a powered sub that is not plugged in or connected to a power source?
Jan 26, 2013 | HP Harman Kardon Subwoofer Sub Woofer...
My mitsubichi projection tv model vs-50605 is getting dark, Do i need to change the bulb
This model does not use a "bulb", it has three picture tubes.
What does happen is the lens for each can get dusty; picture will gradually get dimmer and dull looking.
With set unplugged, remove rear cover (it can be done from front but back is safer for a do it yourself person..
With the rear cover removed look for the 3 large black lens pointing up in the middle of the set--simply clean them with a lens cloth or a paper towel with glass cleaner sprayed on it---this should usually be done once a year.
If they have not been cleaned recently or you are in a dusty environment, cleaning them should improve the picture a lot.
Let me know if you have questions.
SD TECH
Jun 01, 2011 | Mitsubishi VS-50605 50" Rear Projection...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Need replacement handle ( knob ) for Aquabrass Seville 6016
If you can't locate the replacement locally try replacements.com. They have a variety of hard to find replacement items.
Jan 14, 2010 | Aqua Brass AquaBrass 6018 Deckmount 4 pc...
Got a first Gen PS2with problems and I need some help. It can only read Capcom vs SNK 2 and the movie Spies Like Us. Obviously it still works but for some reason just with those two things. Any Idea what...
Your PS2 lens is worn out, its probably covered with dust,all you have to do is to clean it watch this video,this will show you how to clean your PS2's lens.Remember lens cleaning always works!
Oct 26, 2009 | Sony PlayStation 2 (PS2) Console
I would like to know about an engine number they say it is number C5AE6016 (5B11W)its in a 65 F/B date 13T engine code A unit no. 157042 was there a 6016 block???
Yes. It had larger main caps than the typical 289 block. However there are variations on the theme and you could see a smallblock with a 6016 that predates the 289 alltogether (260 or smaller) as well as into the 70s even on a 351 windsor! Hopefully you have a hipo 289 bottom end with the larger caps and thats all you need to know.
Oct 04, 2009 | 1965 Ford Mustang
Cannot disassemble Milwaukee 6016 to replace brushes
exactly what screws did you remove. you have to remove the bottom platen first (pad) then remove the housing screws. you need to remove the fan also and then might need to apply some pressure to split the housing halves.
Mar 03, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Cleaning Mitsubishi VS-50607
CLEANING THE " LENS" MIGHT BE POSSIBLE IF YOU HAVE A LITTLLE SKILL,,UNPLUG THE TV FROM THE WALL OUTLET ,,,,LET ME REPEAT THAT --UNPLUG THE TV FROM THE ELECTRICITY....TAKE THE BACK OFF THE TV---LOOK UP AND YOU WILL SEE 3 PICTURE TUBES POINTING UP,,,ON TOP OF THE TUBES THERE IS A LENS (GLASS)...YOU CAN SPRAY GLASS CLEANER ON RAG OR PAPER TOWELL AND GENTLY RUB OFF ALL THE DUST AND DIRT--USUALLY REALLY BAD IF SMOKERS-- WHEN U GET THRU ,,PUT THE BACK AND REPLUG IN WALL OUTLET--THERE IS ALSO A MIRROR ON PROJECTION TV'S --I RECOMMEND A TECH FOR THAT SERVICING --IF YOU ARE UNCOMFORTABLE ABOUT DOING THIS ----DON'T
THE FRONT SCREENS USUALLY AND RARELY NEED CLEANING...JUST USE A SOFT CLOTH AND RUB TOP TO BOTTOM ON THE OUTSIDE ONLY-GEENTLY TUNICA
Oct 22, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
