Question about Dell 1700n Laser Printer
1720 Dell Laser printer Photoconductor Problem
Our 1720 Dell Laser printer is flashing to replace the drum. I did this with two different drums and it continues to flash. When printing a status page it shows the photoconductor is exhausted. Is this the same as the imaging drum? If it is, why am I still getting the exhausted message? Do I need to resent the printer? Thanks for your input!
  • 3 more comments
  • Anonymous Mar 19, 2009
    I have replaced the Photo conductor, but I am still getting the "Replace drum" and "error" lights blinking.
  • apsparky Mar 30, 2009
    replaced drum, followed instructions to reset...and light is still blinking. I downloaded latest firmware... light is still blinking. When I check the printer from my PC... it still says the drum is down to %6.
  • aakkaa Apr 10, 2009
    I replaced the drum a few weeks ago. It was working fine but now, the printer's giving me the same error light message. The toner is fine, the drum is pretty much new, but it refuses to work.
  • gross1l Apr 17, 2009
    I did figure this out on my own. The key is to open the door to the printer cartridge area. Once I did that it worked fine.
  • buyhomes Sep 06, 2009
    Thank you thank you thank you. You solved my problem, and I did it all by myself following your instructions, no tech support, no computer savvy brother in law, no technically adept husband, just little old me with a little google and someone with similar experience. Thank you thank you. One problem down, I'm sure more will come up.
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Posted on Apr 16, 2009
This is awesome, I was ready to give up on my printer. Thank you so much.
Posted on Aug 10, 2009
I have changed the toner on my dell 1720 it's still not printing well do i have to change my drum
The drum (photoconductor) places the toner onto the page.
If the drum is damaged the print quality will definetly be compromised
Feb 15, 2011 | Dell 1720dn Laser Printer
Our printer is saying it has stopped because the photoconductor kit has reached the end of its useful life.
You need to replace. It is also called the drum unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Dell 1720dn Laser Printer
A Lexmark printer E350d has a message "photocon". What does it need?
Photoconductor unit (drum unit).
These are available new and remanufactured on internet auction sites.
Note that the photoconductor unit is EXACTLY THE SAME (other than the label and part number) as the one for DELL 1720.
Dec 28, 2009 | Lexmark E350d Laser Printer
Dell 1720 laserjet printr
There should have been instructions with the replacment drum unit, for resetting the drum counter.
If not check your manual, or if you can't find it, download ot from Dell website
Oct 04, 2009 | Lexmark E238 Laser Printer
Dell 1720 flashinf replace drum- error.
I believe this message is occur because the laser printer drum needs to be replaced, not the toner cartridge.
These are two different things. The part is a DELL 310-8710 Drum Unit. Just google DELL 1720N drum and you should be able to find one.
May 29, 2009 | Dell 1720dn Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
How do I get our Imaging Drum light to go off?
Follow the four simple steps below to reset the internal drum counter.
1.)    Open the front door.
2.)    Press and hold the “Cancel” button; until all of the lights flash.
3.)    Release the “cancel” button.
4.)    Shut the front door.
Here is a Link to the Dell 1720/1720DN online users guide.
And here is a direct link to Replacing the photoconductor.
-Hope this helps
Apr 07, 2009 | Dell 1700 Laser Printer
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
Mar 03, 2009 | Dell 1720dn Laser Printer
Is my Dell 1700 Laser Printer photoconductor drum truly fried?
The drum collects used toner for apprx. 30,000 pages. After that, the printer recommends that it be changed to prevent used toner from spilling internally into the printer's mechanisms. The whole photoconducter/drum can be replaced. The new part from Dell is apprx. $50.00 US.
You might have reset the "counter" for the photoconducter. Ever  have a water  fillter with an electronic timer? You replace the filter, then you reset the timer? Perhaps you reset the timer without actually replacing the filter. So to speak. :)
The question you should ask yourself is: would I like to spend $30 - $60 [it's cheaper for refurbished parts- Google it] replacing the drum head on a 7 year old printer, or would I rather invest that in a new printer?
Feb 23, 2009 | Dell 1700n Laser Printer
Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Nov 07, 2008 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
6,938 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
