Question about Nintendo Wii Remote Control 4 Charging Dock Station with 4 Battery Packs
Charging pad the remote batteries are dead, won't hold charge anymore...
Have had for a few years, love it.. the remotes wont' hold charge anymore, assume the batteries are just shot. can't find anywhere and was told that l had to buy a whole new charging system with remotes. really?! please advise. thank you, g
    Problem Solver:
  • 17 Answers
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Posted on Apr 25, 2013
rootbeer001
  • 352 Answers
SOURCE: hi my wii remote was put in a charging unit but
Normal or alkaline batteries cannot be recharged. Take out the old batteries and put in new ones. The recharger probably discharged the batteries.
Posted on Feb 19, 2010
  • 128 Answers
SOURCE: wii remote
Try to resync your remote. To do this:
1) Locate the red button under the battery cover on your remote.
2) Locate the red button near the sd card port on your console.
3) Press both buttons within a couple seconds of each other.
4) Wait a few seconds if your remote doesn't sync, retry.
Good luck. Please rate, thanks.
Posted on Mar 06, 2010
  • 4 Answers
SOURCE: Wii rcharger is not charging my remotes
Is your charger a usb type? if it is. and plugs into the wii unit it will only get power to charge when the Wii unit is powered on. I hope this helps.
Posted on Apr 13, 2010
  • 85 Answers
SOURCE: I have a wii remote that wont work
Try re-syncing the remote remove the battery cover and click the red button.
Posted on Apr 28, 2010
kahotshot
  • 57 Answers
SOURCE: I have a wii remote charger and have just
Make sure your charger is plugged in your Wii AND turned on. If you do this, the remotes should charge.
If the remotes still don't charge, there's a problem.
Posted on May 03, 2010
I got a 110cc foreign 4 wheeler in 2007, road it 5 times and been in storage till recently. It's only starting source is wireless remote start. It won't even click, I've charged it, new...
Modern batteries don't like to sit unused for 6 years and may not take and/or hold a charge sufficient for starting.
If you don't already have one, you can get a digital meter for <$20 at auto parts or electronic stores.
While checking across the battery terminals, try to start. If the voltage changes very little, then the starter isn't seeing it well enough to draw current; starter, solenoid or a crusty connector can be blamed.
If the voltage falls down to 70-75 percent when trying to start, then the battery is probably dead forever.
Some, but not all, can be restored by applying 2-4 times their normal charge voltage and monitoring it to see if the drawn current starts to climb.
If it does, DO NOT LEAVE THE HIGH CHARGE VOLTAGE ATTACHED UNLESS YOU STAY CLOSE TO IT.
I generally reduce the applied voltage until the current drawn drops to a few hundred milliamps and then check it every few hours to check progress.
If you can get the charge voltage down to 1.2-1.5 times the rated voltage and still have current flow, the battery may recover.
Apr 21, 2013 | Cars & Trucks
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
The remote for my car alarm won't charge anymore, how can I fix it or where can I take it? I'm in Melbourne.
the battery needs replacement and surely you can do a correct job with a qualified electrician to fit the correct battery.
Sep 03, 2012 | Cars & Trucks
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Won't charge in cradle, shows slide show then goes dark. has power to remote won't charge know matter long it sit on it
The early 880's had problems with the charging circuit. For a while Harmony was replacing these units even outside the waranty period. Not sure if they are doing this anymore. However your remote is recognizing that it is in the craddle because the slide show starts which means the charging circuit in the remote is not passing power onto the battery or the battery is not making a good connection inside the remote. I would pull the battery and clean the little contacts in the remote and the contact pads on the battery. If you have a volt meter I would pull the battery and check voltage. You should see around 4 VDC on the 2 outside copper pads if it is charged. If it is charged and the remote is not working then its time for a new remote. If the battery is dead then it is likley the typical charging problem of the 880 is causing the failure. Hopefully cleaning the contacts both inside the remote and in the charging craddle will solve the problem. Use alcohol and a q-tip to clean all of the contacts.
Good Luck
Apr 01, 2010 | Logitech Harmony 880 LCD Remote Control
Harmony 890 just went dead. Nothing. Nada. Not
I have an 890 also. I've found that the remote doesn't always charge when it the charger. I have to put a rubber band around it and make sure it shows that the the battery symbol on the display is showing that it charging. Or the battery isn't taking a charge anymore and I'd try to replace it. Doesn't really hold a charge very long either.
Oct 27, 2009 | Logitech Harmony 890 LCD Remote Control
Nintendo Wii Remote Control 4 Charging Dock Station with 4 Battery Packs Logo
190 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
