Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Clean the water/ice dispenser on outside of door. Mineral deposits? Can they be removed to clean?
  • 478 Answers
Yes pull tray at bottom remove screws its a few more screws and its out.
Posted on Mar 12, 2009
Maytag MSD2272VEB00 leaking water
Laura,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispenser is ALL the way closed.
Oct 12, 2013 | Maytag Refrigerators
LG LRSC21934 ice maker/water dispenser doesn't work
If your house water supply to the refrigerator is poor it is most likely the cause of the water dispenser and ice maker not working. If you hear the water valve humming when the water dispenser is depressed and no water is dispensed it is most likely poor or restricted water flow to the refrigerator.
If you live in an older home the water supply shutoff valve to the refrigerator is usually in the basement or under the kitchen sink. Many shutoff valves are called a saddle valve and the valve is secured onto a cold water pipe and as the valve is turned clockwise a pin punctures the water pipe allowing water to flow. Saddle valves often become clogged with minerals and can completely block water flow to the refrigerator,. If the valve is corroded on the outside it should be replaced. Ice maker installation kits are available at most hardware stores. Copper water line kits are preferred. Cost is under $25.00. If the Saddle valve is in good shape they can be taken apart and cleaned. Be sure to shut off the main house water and drain pipes before attempting to clean.
Newer homes may have a water box in the wall behind the refrigerator. Sometimes these can become clogged with mineral deposits as well.
Hope this helps.
Mike
Oct 30, 2017 | LG LRSC21934 Side by Side Refrigerator
White translucent particles in water from dispenser
Be sure the water filter is replaced.
Feb 26, 2018 | Refrigerators
Ice cubes sticking in tray before dumping. Can't get it out. Lost manual Need to get it out and clean off the mineral deposits.
you may have a bad mold heater . this causes the release of the ice cubes / but do clean out the deposits . as they also prevent a proper harvest .. after cleaning spray mold with a food grade silicone .
Jul 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE Refrigerator PCF23MGWCC the water dispenser tube on the outside front has a hard yellow substance on the end of the tube. I don't know what it is or how to get the tube out to clean it.
it sounds like you have mineral deposits in the tube, from hard water. you can try using and oxidizing cleaner such as Oxy clean or some other mineral dissolving solution.
Mar 13, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a whirlpool side by side refridgerator about a year or more ago the water dispenser stopped working and now the ice cube dispenser also stopped working it is no longer making ice into the container....
Your water line into the refrigerator is probably plugged up. First, check at the cut-off valve where the house water connects to the refrigerator water line. Mineral deposits often form in these small valves and can block the water flow.
The other possibility is a blocked water line within the refrigerator. Plastic weedeater line works very well to clean out these lines.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cleaning tray on door where water is dispensed
the stains is from hard water.(calcium)you can get a new tray from sears.com
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
234 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
