Question about Ruud UBHC Air Conditioner
The rudd a/c unit is making too much water - Ruud UBHC Air Conditioner
  • 31 Answers
Not really. You have alot of moisture in your home and it is removing it is all. Only problem with to much liquid is if it is forming on the lines as condensation and dripping on your ceiling. Make sure your drain pan is clear of any gunk and the drain pipe allows good flow to the outside.
Posted on Apr 23, 2013
What is the AFUE of my Rudd Achiever 90 Plus with model number UGRA-07EMAES
Per Rudd's website and also as the name implies, the min rating is 90. The 90+ can be as high as 93 but is stated as "plus" to cover the many possible installation scenarios which will impact overall efficiency of the unit.
Sep 11, 2014 | Heating & Cooling
How many tons is a rudd model ubhc-14j06sfd?
I believe the "06" in the model number has been reversed. It should read UBHC-14J60SFD. This would make this unit a 5 ton unit. I hope this helps:) Have a great day!
Jun 18, 2014 | Ruud UBHC Air Conditioner
Getting excessive condensation causing water problems at base of unit. Bought new pump but problem returned. Cleaned lines to outside by using wet/dry vac. How do I get to evaporator coil to spray it and...
Hello, in order to get to the evaporator coil you must cut into the plenum above the Furnace. This will require sheet metal tools and being very careful not to puncture the coil. Many times a cracked condensate pan under the evapoartor coil can cause water to leak down to the base of the unit.
Sep 15, 2011 | Ruud UBHC Air Conditioner
Rudd water heater leak. I have a six-year-old unit. I suspect it is no longer covered by warranty. Can it be repaired or must it be replaced?
depends were and whats leaking, have an engineer look it over,see if it can be, and how much it will cost to repair,compaired to the cost of replacing it
Sep 07, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
RUDD MODEL# UAMB-048JAZ AIR CONDITIONER
service once a year clean dirt and hose the coil out make sure power to outdoor unit is off also make sure you keep a new air filter change about every 2 months you should also have a tech test you pressures this could cause poor cooling also need to clean inside coil also a service tech will probaly need to do this good luck
Aug 30, 2009 | Ruud UAMB Air Conditioner
Both inside and outside unit running but not cold
No, there is really not much you can do to test the amount of freon level in the system. The best thing you can do is to be sure the outside coil is as clean as you can get it. I usually use a grease cutter type chemical and a hose. Just be very careful not to bend the fins with the water pressure. Also kill the power at the breaker or disconnect prior to cleaning.
Aug 16, 2009 | Ruud UBHC Air Conditioner
When my Rudd air conditioner/heat pump is running, water pours out of the bottom of the unit. What could be causing this?
It's working properly. Air conditioners make it feel cooler by removing humidity from the air.
Aug 04, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
59 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
