Question about Dryers
Kenmore dryer squeak - Dryers
  • Dryers Master
  • 7,482 Answers
Hi Bruce
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
How do I fix my Kenmore electric dryer which is squeaking.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 22, 2011 | Kenmore 83142 Electric Dryer
When I run any cycle, it is squeaking and making noises. It sounds like the dryer cylinder is loose. Kenmore Elite He5t Gas Dryer
heatman101
Dec 31, 2010 | Kenmore Dryers
Kenmore 70 Series dryer squeaks while tumbling - otherwise it works - what might be causing the squeak - a belt or loose screw?
heatman101
Dec 16, 2010 | Kenmore 64722 Electric Dryer
Model 417.84082500 kenmore dryer is squeaking. What do I replace?
heatman101
Dec 16, 2010 | Kenmore Dryers
Have a Kenmore 70 series. It"s squeaking while running. Lubricant? Bearing?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 30, 2010 | Kenmore Dryers
Unusual squeak noice
easy way is a bit of furniture pollish on belt / fly wheel
Jul 23, 2010 | Kenmore 74602 Gas Dryer
Kenmore dryer 66812690 squeaks very loud while runnung
The squeak is quite possibly a bad wheel.
I have repair photos and a video along with a manual HERE
Mar 13, 2010 | Kenmore Dryers
417.83142201 just replaced felt pads, upper and
try to lube the rollers on the back wall, where the drum mounts , sometimes the wheel bearings tend to make noise specially when dryer is overloaded and hot
Feb 05, 2010 | Kenmore 83142 Electric Dryer
Squeak
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Nov 29, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Dryers Experts
