Question about Dell Dimension 3100 PC Desktop
How do I get a dell dimension 3100 case open it seems pop riveted shut. is there a trick or do the pop rivets have to be drilled out
1. Stand in front of the PC i.e. you face the start button.
2. Push the tab at the top back of the casing
3. Pull the right hand side cover of the casing and it should just pop open - the latches are at the bottom.
I think most people try to open the left side and wonder why the ......
Posted on May 22, 2009
  • Dell Master
  • 1,183 Answers
follow the instructions given on the following link
Note: the above link also has the complete service manual for your computer
Posted on Mar 12, 2009
How do I remove the rivets on the airbox? can,t seem to pull them
I don't know year--make--model? Can't see anything from here, I'm not sure about your problem? Depending on the issue, sometimes I drill out rivets. Then I use a pop rivet to reinstall or nut and bolts, it just depends on the issue.
Nov 17, 2017 | Cars & Trucks
How to replace spiral rubber that are riveted on?
Pieces of old conveyor belt, a craft knife, a drill and a pop riveter. Is what I would do. Or you could drill the old pop rivets out and use stainless steel nuts and bolts for ease of replacement.
Jan 26, 2016 | Garden
My frigidaire microwave door is sagging and is about to fall off
You will need new door and hinge replaced
send model # for price quote
May 13, 2015 | Frigidaire PLMV169DC Microwave Oven
Replacing the pull cord on a scott bonnar sx4000
Home Depot and other home improvement stores sell universal replacement pull cords for less that 4 dollars. Instructions are on the bag. Look at the screen covering the pull cord to see if it is bolted on or pop riveted. If it's pop riveted you'll have to drill out the rivets to get at the cord. Have a pop rivet tool and the proper sized rivets ready to re install the cover
Sep 23, 2014 | Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
How can i attach a lock on my refrigerator
Here is an easy way. Buy a lock hasp from a local hardware store. Mount it to the right or left side, depending on which way it opens by holding it up so that the entire lock hasp covers the opening of the door seal width, but allows you enough room to drill the holes into your refrigerator sheet metal. If too small then buy a larger or if to big buy a smaller hasp. Use common sense and your best judgment. Once you have found one the correct size, you will need to mark the position of the holes that you will have to drill through the sheet metal. Once the holes are marked they will have to be drilled. You are going to permanently mount this hasp to the refrigerator with a pop rivet gun, so ensure you want to do this before you drill any holes. You will also want to buy a hasp that has holes no larger than 1/4" to make it a solid mount. Once you buy the pop rivets that fit through the holes in the hasp and are long enough to grab the sheet metal of the refrigerator, use the recommended drill bit size for the rivet. That info is on the rivet box. Once all holes are lined up and the door and hasp will allow you to put a small padlock on it use a pop rivet gun to permanently install the hasp to the side of your refrigerator. After it is installed, simply close the door and put your padlock on it and snap it shut to lock it. I learned how to do this, because sadly I lived with someone that had an eating disorder and the food had to be locked up. I pray you aren't going through the same thing, but this works!
Feb 11, 2012 | GE Refrigerators
Driver's door won't open from the inside
The little arm on the inside of the interior door handle has most likely broken. It is part of the handle assembly and not sold seperately. To replace it you have to remove the inner door panel to get to the handle which is usually pop riveted to the metal part of the door structure. If it is pop riveted you have to drill out the pop rivet to remove the handle. I usually use a small bolt to hold the new handle in place. Be carefull when drilling out the pop rivet! Roll the window all the way up so when you drill through the rivet you don't accidentally hit the glass with the drill bit and break it. Although there could be something else wrong, I replace a couple of these a month for just this type of problem. Hope this helps!
Jul 17, 2010 | 1999 Chevrolet Suburban
Broken recoil on 10 briggs the recoil rivets came out of housing
I have had the same problem and use a pop rivet gun with steel rivets when reassembling the housings. Frequently these rivets get loose, & need drilled out & changed. I am assuming that the rivet holes in the housing are not elongated or you might have to drill to the next larger size rivet to install them. Hope this helps you, Rick
Apr 11, 2009 | Briggs Electrical Supplies
Need to get inside door panel rivets out know easy way help
take a punch to the center of the rivet where sticking out nock it threw then drill out with drill bit
Feb 18, 2009 | 1995 Chevrolet Silverado 2500
Replacing electric window Motor 2000 Pontiac Sunfire
The glass has to be taken out first. 2 X 10 MM nuts. Knock out rivet centers and drill out rivets. It will come out the port in the door. Reverse procedure and you will be done.
Jul 26, 2008 | 2000 Pontiac Sunfire
Dell Dimension 3100 PC Desktop Logo
5,361 people viewed this question
Alun Cox
