Question about Chrysler 2008 300 Touring
Wrench size front brake calipers
Changing front brake pads ,what type of tools will i need
    New Friend:
    Problem Solver:
  • 8 Answers
Set of metric sockets. front should be 13 or 14 mm back is 10 mm need c clamp to push in piston in caliper that's about all u need not hard very simple
Posted on Oct 21, 2013
What tools are required to change 98 buick park ave front brake pads?
The correct size socket or wrench. I use a c clamp and the old break pad to push the calipers down and grease the caliper to prevent squeaking. Hope that helps
Jul 12, 2015 | Buick Cars & Trucks
What size Allen wrench for 2001 escape front caliper?
i just changed my front rotors and pads on my 2001 escape, 6 cylinder. everyone was wrong on the wrench sizes, including the idiots at my local ford dealer. to get the brake calipers off I needed a 7mm hex bit. to get the caliper bracket off I needed an 18mm socket, it was a very easy job but check your wrench sizes first, it seems that every year and model uses different sizes.
Mar 11, 2012 | 2001 Ford Escape
What size allen wrench do i need for the front brake calipers
For front brake pads replacement you only need usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
Instructions for front brake pads replacement.
For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose!
2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper.
3. Now you must thoroughly clean the brake calipers (free of grease).
4. Remove outer brake pad from brake carrier.
5. Pull inner brake pad out of brake caliper piston.
6. Check up the brake fluid level on the reservor, and emptying if neccessary!
7. Push piston back into brake caliper housing.
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward).
9. Install outer brake pad into brake carrier.
10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm.
11. Install both caps.
12. Insert retaining spring into brake caliper housing.
Important note: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!!
Check brake fluid level and top up as neccessary!
Sep 03, 2011 | 1994 Audi 100
What size bolt holds the brake and caliper on a 99 Volkswagon Passat
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
Mar 27, 2011 | 1999 Volkswagen Passat
I am changing my fron brakes on an Audi A3 1.8 1998 model and want to know the allen key size for the caliper?
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. (On my car y have 288 mm). After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
Feb 21, 2011 | Audi A3 Cars & Trucks
What size allen wrench to remove front brake caliper
Oct 19, 2010 | 2005 Ford Escape
Wat tool do i need to remove front and back brake calipers so i can replace brake pads on a audi a4 2002 2.0 se
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. (On my car y have 288 mm). After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Check up the brake fluid level on the reservor, and emptying if neccessary! 7. Push piston back into brake caliper housing. 8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 9. Install outer brake pad into brake carrier. 10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 11. Install both caps. 12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!! Please Rate my Response! Thanks!
Aug 01, 2009 | 2002 Audi A4
Passat 2003 tdi, brake pad change..
Proper size wrenches and a large C-clamp to push piston back into the caliper is only tools for the front, but back disk brakes require special tool to TURN the piston as it is pushed back into caliper to reset emergency brake. This tool can often be borrowed from Auto parts store or purchased from Harbor Freight http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40732 for about $20. Don't try to service rear disks without the tool, Calipers can be broken if not retracted properly!
Jul 03, 2009 | 1999 Volkswagen Passat
Tool for 2006 brake calipers I need size
buy a set of the torque bits they come in sets of 4 or 5
Jun 14, 2009 | 2006 Mazda Tribute
You shouldn't need to remove the calipers altogether just to replace the pads. You have remove the split pins or retaining springs on the old pads, then prize back the caliper pistons enough to remove them. Then push the pistons back some more enough to get the new pads in. Then reassemble and test.
Oct 23, 2008 | 2007 Toyota Yaris
Chrysler 2008 300 Touring Logo
55 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
