Last memory message on dvd
Hi I have a technika tv/dvd and when switching it on it appears to load dvd then it comes up with a message on screen last memory??? It won't play the dvd and its a genuine one not a copy. Any suggestions as to what the problem may be. This tv is about 8 mths old.
  • 81 Answers
SOURCE: DVD S1000 video player
A new Laser pick up will fix your problem expencsive repair
Posted on Dec 15, 2006
SOURCE: DVD not playing
I own a Venturer PVS 177G portable dvd player and it does not come on. Occassionally it blinks off and on but does not playdisc at all.
Posted on Nov 29, 2007
Warf135
  • 137 Answers
SOURCE: Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
Posted on Feb 23, 2011
  • 159 Answers
SOURCE: I have a Playstation 2.
Try starting the game without the memory card. If it starts up then you know that you have a bad memory card.
Please remember to rate my solution to show your appreciation!
Posted on May 31, 2011
Testimonial: "Thank you for replying so fast! However, I need to ask more on the question, so I'm posting another question right now-please help! :P"
  • 127 Answers
SOURCE: Purchased a Technika Model 19-220. 8 months ago
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Posted on Jun 06, 2011
Technika tv
It sounds that the problem to your TV is with its DVD loading tray. A pure mechanical fault indeed. Not loads the disc properly to its seating. A motor fault, or a gear wheel fault, or a leaf switch fault could be. Anyway, you have to take the DVD mechanism out from the TV, to get the actual problem could be resolved. Really this is a semi skilled work. It will be best to contact any service technician in this case.
Sep 19, 2013 | Televison & Video
I have TECHNIKA SH-A366 when I switch this on this message comes on the screen CARD ERROR and it wont allow me to take any pictures please someone help me solve this problem.
It sounds like the memory card (what stores the photos) may be faulty, not inserted correctly or may need cleaning. There should be a memory card slot on the side or underneath the camera. Once you have found the slot push the memory card and it should click out of place. Give the memory card a quick blow and reinsert it, if the error still appears it may be the fact that the memory cards capacity is too large for the camera to handle or is incompatible. If you have another memory card, try that. Comment if you still have an issue. Good luck :)
Jun 02, 2011 | Cameras
Technika universal remote tr41r remote codes for technike tv dvd freview combi
Hi, I have a Technika LCD26 620 TV and ave a Technika TR41R remote contro but i cant find the code?
Any help please..
May 31, 2011 | Televison & Video
How to make my Samsung HT-BD8200 region free?
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
You may have to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before you get the Region Free message if you're not quick enough.
May 08, 2011 | Samsung HT-BD8200 Theater System
Is there a multiregion hack for Technika HDMISS10 DVD player ?
Technika HDMISS10 HACK. 1.open tray. 2.insert any disc. 3.press set-up. 4.from language menu,select "encoding". 5.press play. 6.select "unicode". 7.press play. 8.press set-up. 9.VERY IMPORTANT!! close draw,press "zero" fast as you can while disc is loading. "not allowed at moment" appears in top right of screen but keep pressing "zero" fast as you can and it will change to "O". player is now multi region.
Nov 27, 2010 | Televison & Video
May 18, 2010 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Technika SC500172 tv/dvd won't come out of standby.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Sep 01, 2009 | Televison & Video
Blank screen when tv switched on -audio only
definetly not.D.I.Y. its a convergance fault needs a service centre
Dec 10, 2008 | Televison & Video
Technika LCD19id - No power to internal fuseMy LCD 19id-107 tv turned itself off and will not come back on. I have power to the 3 pin power connector at the rear of the tv. However i have no power to the...
I have a Technika 22 inc hd flatscreen that will not power up. you can here the dvd running if you load a dvd but the television side wont power up.I have tried to find the internal fuse but have had no luck.Anyone help?
Nov 15, 2008 | Televison & Video
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
