Question about Fender& Standard J Bass Artic
Fender Jazz Bass E string saddle vibrates down
E string saddle vibrates down while you are playing a song. It is a left handed J Bass. Any help is welcome! Thank You Mike
  • 1 more comment
  • srvrocks Mar 13, 2009
    Thank you very much. I will try the saddles and the neck. It also looks like the small set screws on that saddle, looks like they are a bit larger on the opening holes where they adjust up and down, very very loose to adjust. Thanks again for the info.mike
  • Anonymous Mar 20, 2014
    Someone claims to be selling a 2006 MIA Jazz bass - do they all have string-through (this one doesn't)
  • Anonymous Mar 21, 2014
    fender tribute jazz bass
  • 19,396 Answers
Hi Mike,
If the sound is like a string vibrating against something, ensure that is not strings (usually G) vibrating against the bridge.
Ensure that the two screw on the saddle are well in place.
Ensure also that the vibration is not coming from a string vibrating against the frets, in that case you can fix the problem by adjusting the action and rectifying the bow of the neck.
In either case, if the sadde and neck bow are cause of vibration, try tweaking the saddles a little, and lowering the position of the saddle a bit downward. Try also to rectify the neck. turning the apposite screw.
Posted on Mar 13, 2009
    Problem Solver:
  • 5 Answers
Once you get the saddles adjusted where you want them, try just a little clear silicone on the end of a tooth pick, and dab it just under the saddle on the height adjustment screw. It is clear, and only a bit on the tip of the toothpick should do the trick. Once it dries, it's like rubber, and should keep the adjustment screws from losening up. It is easy to remove as well. You won't be able to stop all the vibrations on the guitar....it's the nature of the beast. The string vibrating in it's normal state will cause the screw to drop. It IS important to have equal pressure on both adjustment screws. Good luck!!
Posted on Nov 21, 2011
Age of my fender 4 string bass with serial 238784 on back plate
I would need the complete serial #s, this serial # would be a 1968. Fender did not manufacture a Deluxe (or active) Bass guitar line at that time.
Aug 12, 2014 | Fender Deluxe Active Jazz Bass Electric...
Information for Fender Jazz Bass Serial Number MZ0276880
It is a Mexican Fender Jazz Bass manufactured between 2000 and 2001 (MZ0 + 5 or 6 digits 2000-2001)
Mar 31, 2014 | Fender Music
Need to find out what year was the fender jazz bass serial #z2135395 made
# z2135395 Your Jazz was built at the Fender Corona, CA. USA Plant.
2002-2003
Jan 05, 2013 | Fender Deluxe Active Jazz Bass Electric...
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
I have an squire vintage modified jazz bass. the problem is that the nut is too high...and i can`t intonate corectly. should i take it off and resize it, or just ''eat'' from the holes that hold the...
I would suggest that you search the web regarding this problem. It is rare that the nut (near the headstock) would cause a problem with intonation. There is a minimum clearance to the first fret which the height of the nut controls. If it is too low that will cause fret buzz. The bridge would be a more probable cause with intonation.
Mar 30, 2010 | Squier Stop Dreaming Start Playing...
I dont know how to put a whammy bar on a fender stratocaster
Look near the near the highest string at the the silver part known as the bridge.There should be a hole right near the bottom of the thinnest string.Take the threaded end of the whammy bar and screw it in clockwise into the body.
Sep 20, 2009 | Squier Stop Dreaming Start Playing...
Own Peavey Cirrus 5 BXP , Strings are to close to the frets.
If the problem you are having is buzzzing, yes. This height is called the "action" of the bass. You can change either or both the saddle and bridge. I would recommend that you have this examined at a music store to verify that the neck is straight and does not need adjustment too. This is part of normal upkeep for these. Expect an overhaul cost of about $50 if you have it adjusted.
Dan
Mar 19, 2009 | Peavey Music
Fender& Standard J Bass Artic Logo
615 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
