Question about Zenith A19A11D 19" TV
Coax receptor broken! Want to replace part.
I'm not sure what this part is called but it is the silver receptor where you connect the coax cable to the TV. I'm looking to replace this part but I am not sure what it is called.
The model number is Zenith A19A11D
It is the only connector for the cable on the back of the TV. It is very old school.
    Problem Solver:
  • 4 Answers
If you truly need to replace the part then go out to a tv/mechanism store and buy the 12 in receptor to replace.
Posted on Mar 12, 2009
2008 Malibu LTZ 3.6 engine. Diagnostic code B2470 that is an ONStar antenna issue , and P70496 I called Chevrolet Dealer, But these People have lost their minds with the prices they Quoted . ! I need to...
P70496 This is not a code . Has nothing to do with emission's .Now P0496 does P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
Purge solenoid is probably bad .
Automotive Evaporative Emissions Part One
B2470
Cellular Phone Antenna Circuit Malfunction
VCIM
DTC B2470
DTC B2470 04: Cellular Phone Antenna Circuit Malfunction Open Circuit
The cellular antenna is connected to the communication interface module (CIM) with a RG-58 coax cable. The CIM polls the data from the cellular antenna once every second.
Circuit/System Testing
Ignition OFF, disconnect the cellular antenna coax from the CIM module and the cellular antenna.
Ignition ON, test for less than 1 volt between the antenna coax center terminal and ground.
? If greater than the specified range, replace the antenna coax.
Ignition ON, test for less than 1 volt between the antenna coax outer shield and ground.
Test for infinite resistance between the antenna coax center terminal and ground.
? If less than the specified value, replace the antenna coax
Test for infinite resistance between the antenna coax outer shield and ground.
Test for less than 5 ohms at the cellular antenna coax center terminal from end to end.
? If greater than specified value, replace the cellular antenna coax cable.
Test for less than 5 ohms at the cellular antenna coax outer shield from end to end.
Test for infinite resistance between the antenna coax center terminal and the outer shield.
? If less than specified value, replace the cellular antenna coax cable.
If coax cable tests normal, replace the cellular antenna.
Clear the DTCs and operate the vehicle within the conditions for running the DTC. Verify DTC B2470 does not set.
? If the DTC sets, replace the CIM.
Jan 08, 2018 | Chevrolet Cars & Trucks
I am transitioning our spare bedroom into a tv room. There is a coax wall plate in the room. I bought a new satellite receiver but do not think the coax wall jack is turned on. I can not get a signal...
Hi
1st remove the plate from the wall cheek if there is a coax cable connected to it also make sure the plate is not broken if it is of the printed circuit type. 2nd trace out where the cable goes to most likley into the loft if you are using this to receive sat pictures the this lead will need be to connected to a sat dish or a aerial for tv (free view) if you have to replace any cable use the correct type.
regars Derrick
Jan 30, 2011 | D-Link Televison & Video
Most of the channels breaking up despite auto retuning
could be one of a few things,
low signal strength, aerial out of line with transmitter.
bad coax connections losing signal strength.
coax broken inside, or old and not low loss.
Get the aerial checked for direction, half a degree out of line over a few miles and you will lose a lot of signal strength, as will old coax (aerial cable) and if you are using an unshielded coax you could be losing signal strength through the cable itself. Replace the connecters and try to use a straight run of cable instead of having joins in it as these joins, even if using connecters, will cause a weak signal. If yiu are running more than one tv off your aerial, invest in a booster.
Feb 06, 2010 | LG 32LG30 32 in. LCD HDTV
The attachment point for the coax cable was pulled off-broken off
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
Dec 03, 2009 | Sharp 27H-S60 TV
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
Coax that looks like RCA?
There is a distinct difference between coax and phono (rca) cabling. Coax, sometimes called RF, is a cable that carries audio and video at the same time, what we call a "modulated" signal. RF connections look as if they are threaded on the chassis of your TV or VCR etc. A lone "Phono" cable moves either audio or video, but not both at the same time, unlike coax.
If you are attempting to patch RF, your cable must be coax at both ends.  Hope that helps.
Jan 07, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
The cable coax male connection is disconnected from the television
The coax connector you describe is called the F connector and the silver box it is attached to is called the tuner. The original F connector or a replacement F connector can be soldered back into the tuner, but the metal frame of the tuner must be straightened out and the center pin must be delicately reattached too. This is quite an easy job but requires some labor, assuming that nothing was jammed into the tuner when the F connector was out and the coils behind the F connector have not been disturbed. I usually charge about $40 to reattach F connectors but if I have to replace the tuner I charge about $50 because it is a lot less labor to replace the tuner and they can be purchased for about $25.
Jul 17, 2007 | Sanyo DS25390 TV
Televison & Video Logo
206 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
