Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
SD error, not detergent, not filter, basket is engaging
I'm this close to burning this washing machine. It has been nothing but a headache from the day I bought it. I have replaced the balancing springs 3 times, due to problems with that. This is the third time I've had the SD error, the first time a WHOLE dishcloth got under the basket. The second time a washer was blocking the drain whole. This time, I can find NOTHING blocking it. The basket is engaging, I used HE detergent, trying different cycles doesn't clear it. Hoses are clear. Not a lot of water in the tub either.
blueextc3221
  • 15935 Answers
SOURCE: won't drain properly after trying all troubleshooting options
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
  • 6277 Answers
SOURCE: Good day: The Dispenser on my whirlpool duet F.L.
I suspect that it is the conditioner/softener tray which is causing water to 'overflow' into the other parts and needs a thorough clean! Here are my general guidance notes-
Remove the complete drawer. To do this you will have to do one of the following-
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catch underneath or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
I hope this is your problem and solution!
Good luck,
John C
Posted on Feb 26, 2011
Testimonial: "John: Thank you very much for your technical help regarding our Wheelr. washer, followed your instructions and used the washer twice and so far all ok"
  • 202 Answers
SOURCE: We have a Whirlpool Cabrio
you need a new RPS sensor ... its by the motor ... I can't get you a part number cuz your model is not working
Posted on Mar 22, 2011
  • 731 Answers
SOURCE: Top load Whirlpool close washing machine
Sounds like the pump is leaking It's item 22 on this diagram and less the $50 from Sears
Installatin is pretty staright forward remove the hoses, remove the clips slide off old pump and reverse the process
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts//Model-LA4800XTW0/1198/0153000/O2001499/00006
Posted on Jun 24, 2011
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio he washer stopped
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 20, 2011
How to fix error message SD on our cabrio washer
Check the drain hose for kinks. Then check entire circuit: tub drain>drain hose filter>drain hose pump> drain hose for blocks. The particulars for your model would be in the owners manual or service maual.
Sep 06, 2014 | Whirlpool WTW6400SW Cabrio Washer
Washer doesnt drain
Suds Detection
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify:
Excessive detergent usage.
Basket cannot engage during drain step.
Mechanical friction on drive mechanism, not allowing basket to engage.
Nov 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I stop the oily residue in my brewd cup of coffee? The coffee maker is new. The residue is not from our filtered water.
Thoroughly wash the pot and the basket with a good oil/grease remover (detergent) such as DAWN dishwashing liquid.
Then run White Vineger/Water (50/50) mix through the coffee maker TWICE, with the basket and pot in place. (NO coffee, nothing in the basket)
DO NOT RUN any detergent or soap through the coffeemaker at any time.
Then, run straight water through the coffee maker TWICE (no coffee, basket empty)
Then wash the pot and basket out AGAIN with a good detergent.
This will remove any residue that is in the coffeeemaker from the factory.
As coffee brews, there IS a slight amount of oil that is produced. The coffee itself has oils in it, and is part of its flavor, and freshly brewed coffee will have a slight oil residue.
Jun 24, 2011 | Rival Coffee Makers & Espresso Machines
Error code sd I tried canceling, starting over, rinse and spin, unplugging it oh and sparks when I plug it back in at the outlet Help
Suds Detection
Mechanical friction on drive mechanism, not allowing basket to engage.It sounds like there is something causing a lot of friction and when you plug it in it has a load on the motor and you will get sparks.
Jun 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Lg washing machine WT - R852... LE error..bad burning smell
For LG washers 'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 21, 2011 | LG Washing Machines
All lights flash says sd
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: Excessive detergent usage. Basket cannot engage during drain step. Mechanical friction on drive mechanism, not allowing basket to engage.
Sep 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer is constantly showing 5d. What does that mean?
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Lid lock will not lock
You can check for the correct part before ordering it on the reliable site :
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts?s=b6a11c212
Thank You for contacting Fixya and please accept the solution if it has helped you.
Jun 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Sd code: Washer sounds like it is straining during the
This is a suds error. Too much detergent,wrong kind of detergent or a blocked drain pump filter.
Remove the bottom front panel. Unscrew the filter and clean it out. Run a couple cycles with no detergent to clean out the tub. Use only HE soap and the correct amount.
More soap causes problems and does not get the laundry any cleaner.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
Jul 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
