Question about Frigidaire Affinity FAHE1011MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 8 Wash Cycles, 4 Temperatures, 600 RPM Spin Speed, Fresh Water Rinse and DuraMotion Tub Lifetime Warranty
BEEPS TWICE AND BLINKS
All the lights blink twice and machine will not work. I have tried unplugging it and plugging it back in several times, then it blinks and beeps three times then goes back to the two times. I have even unplugged it from the surge protector and plugged it into the wall, along with other outlets, same thing. Any ideas what is wrong and how to reset it??
Benimur
  • 6966 Answers
SOURCE: WASHER WON'T START
For some unknown reason(s) the Live Session/Chat window closed. I hope that the two buttons resolve the issue, otherwise, pls click on "Ask Me" for a follow-up solution.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 05, 2008
the terrier
  • 94 Answers
SOURCE: Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Posted on Oct 28, 2008
  • 3 Answers
SOURCE: the wash beeps all the time
I had the same problem about a year ago. Out of the blue, the washer would start beeping and blinking. While the washer would run fine, it was annoying. Anyways, I had the service guy in and he had to replace the control board panel (under warranty). Without warranty, the cost of the part would be ~ 150.00. It was fine after that.
Posted on Jan 14, 2009
SOURCE: Constant beeping
I have an ATF8000 that did the same thing, unfortunately when this happens the entire control board must be replaced. I bought it for about $130 from a local appliance repair shop who then installed it for about $50. In all with tax it was near $200 repair.
Posted on Aug 20, 2009
SOURCE: 2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Posted on Apr 24, 2010
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Maytag top load washer lights blink twice and stops working
Probably a error code. Check your Owner's manual, Troubleshooting section. No answer, try MFG customer service.
You may try unplug for several hrs. Black box may reset.
Feb 27, 2015 | Maytag Washing Machines
What can I do to fix cem256 ice machine that the refigeration light blinks twice ?
http://hvac-talk.com/vbb/showthread.php?679751-Scotsman-CME256-Water-Diagnostic-Light-Problem
May 15, 2014 | Scotsman Ice Machine - 290lb...
Prm 25 projector
Not what you want to hear but this error means the lamp did not ignite. The most common problems I have had with projectors has always been the lamp itself, so if you have another or know someone with a good lamp try that first.
Jan 15, 2014 | Promethean Board Lamp for PROMETHEAN PRM25...
Panasonic cinemavision 1080i power light blinks red twice, will not turn on
The clicking sound is a safety device that prevents that TV from starting because a fault has been detected.
The fault is also indicated by the two blinks. Two blinks point at a problem with one of the low voltage lines (it should be 15V) from the power supply. The PSU is the part to be tested and eventually replaced. Before calling the technician try to unplug the power cord and leave the TV to rest for about one hour before restarting.
Nov 18, 2013 | Televison & Video
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Frigidaire Affinity FAHE1011MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 8 Wash Cycles, 4 Temperatures, 600 RPM Spin Speed, Fresh Water Rinse and DuraMotion Tub Lifetime Warranty Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
