How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I have a Samsung TV/VCR 19in Combo I have lost the remote and wish to use a playstation with it. The TV has a scart port and an additional AV point. Yet with out the remote I can not use. Is there a combo of buttons I can press on the front panel to change to AV input? I have tried an universal remote, however it only works on the VCR setting and does not allow AV change. How can i turn to av without a remote control.
  • Anonymous Mar 29, 2009
    I have a samsung modle CXJ1952 How can I turn to AV without a remote control? Is there a replacement remote I can buy. it's a tv vcr combo.
    Thanks
  • Masterofsc Mar 29, 2009
    Thanks
  • 89 Answers
You might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Posted on Mar 13, 2009
2 Suggested Answers
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
How do i get vcr to work with tv
The connection would be ideally a SCART cable or a phono AV cable ( red, white, yellow) which are you using? Then turn on TV, then turn on VHS, if the VHS does not show on screen, press the AV/Mode button on remote until VHS on screen!
Dec 15, 2014 | Disney Princess TV/DVD Combo
We have an old style(not slim) Playstation 3 and cannot get either av channel, on the TV detailed below, to play it. all plugs are plugged in. we have tried both scarts and the side (yellow, red, white)...
If you've used the HDMI port or another sort of connector and you're switching to a DIFFERENT connector, you need to default the video output on the PS3.
First, you need to plug the PS3 into your tv with just the cables you're going to be using.
Then, press and hold the power button for 5 seconds.
It should beep and a picture should appear on your screen.
Mar 22, 2011 | Philips 21PV375 21 in. TV/VCR Combo
A/v channel
this have av channel and the av port is at the side front view of the television and can change it to av by using the remote control of the television.
Take care..
May 28, 2010 | Samsung CXJ1352 13 in. TV/VCR Combo
How do i connect the vcr to the tv so it records on the channel i want. i tried recording but was a different channel. i do not have the remote for the vcr
If the TV has a scart socket and the vcr also, you can connect it that way, with a scart lead. Then all you need do is press the channel button on the VCR till it reads AV. There may be more than one AV socket so use the one with the connection of the scart lead, it should say on the scart socket what it is. IE: AV1. All you need do is set the channel on the TV you want to record, the press record.
You won't be able to watch another channel though while recording.
Some TV's with multi scart have options for AV settings or recording from the TV, so check these out.
Consider buying a universal remote.
Feb 11, 2010 | Emerson EWV603 VHS VCR
Won't record..
try swapping the scart lead to the second AV port on the player sometimes 1 is input and the other output run your tv cable direct to the player and scart to tv hope this helps
May 15, 2009 | Philips Magnavox DVD/VCR Dual Player
No sound on TV but VCR is OK
Hi there, This sounds like an input control error.
If you find the menu section, then choose Av inputs, you can adjust the settings, I.e. stereo Video or Av (if you are using scart leads then choose Av.
Hope this helps, Chris
Nov 09, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Changing input jacks
has your remote control got a AV button on if so then press this till AV 3 if your video has 2 scarts at back and av jacks in front if your remote has not got AV button press the ch- key till you see AV3 on desplay. If you still have the user manual refer to this. hope all goes well
Aug 20, 2007 | Emerson EWD2204 DVD Player/VCR
Need help connecting a playstation.
purchase an AV Scart Hub (a switching box/scart box),and connect all of your devices to your tv directly.
Apr 24, 2007 | Philips Magnavox 27MT5405 TV
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Televison & Video Logo
1,682 people viewed this question
Top Televison & Video Experts
Electro Med Services...
