Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Dry white powder on dishes after washing
GE profile dishwasher leaves dry white powder on the dishes after washing. Regardless of the type of soap used and in spite of additional rinse cycles
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Hard water is the reason for the spots. There is a new product out at www.dishwasherfilter.com that is made specifically to fix this problem. It filters the water going only into your dishwasher leaving your dishes spot free with every load. It is very affordable and guaranteed to work or your money back. You will love the way your dishes look after the very first load.
Posted on Jul 30, 2009
    Guru:
  • 462 Answers
Hard water maybe?Or your heating element in the bottom may need some cleaning. take pour some vinegar on it and see if the lime bubbles. if so get something like lime away or CLR and pour it on the element let it set for 5 to 10 min then run it through a cycle for rinsing it all out. If the problem goes away for a while then comes back within 90 days I believe you need a water softener.
Posted on Mar 12, 2009
My Samsung model #WA4H7000AW/A2 seems to always need an additional rinse to get rid of soap left behind. Is this a common complaint ?
Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
Dec 19, 2016 | Samsung Washing Machines
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
My dishwasher is leaving a white film powder on all my dishes. It appears the powder is in the dishwasher. How do I clean it out? How do I clean my Ge range profile rangetop?
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 29, 2011 | GE Ovens
My dishwasher is not cleaning the dishes as well as it used to. Are there some simple things I can try before calling a tech?
Use a good quality powder detergent.
Check your incoming water temperature, 120 degrees plus.
Use a rinse aid such as Jet Dry.
Start the DW without soap and no dishes.
Once it starts the wash cycle pour in 1 quart of WHITE vinegar and let it finish the full wash cycle.
Then load up with dishes and powder detergent and run a load.
Jan 13, 2011 | KitchenAid Dishwashers
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Dish soap is leaving a build up on the interior of the dishwasher
Hi. Run your hottest and longest cycle with no soap, no dishes and 2 cups of white vinegar. Also, run the hot water into the sink before starting the dishwasher. Once the sink water is as hot as it gets, then push the start on the dishwasher. J.
Jun 23, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our dishwasher is linking suds after the cycle begins BUT ONLY 1 of 10 loads does this happen. What could cause this problem? Thank you.
Use dry powder soap and just enough to clean the dishes. Usually around 2 tablespoons is enough in a modern dishwasher and soft water after giving the dishes a good scrape. If you prerinse, use much less soap!
Dec 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
386 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
