Question about Microsoft Windows XP Professional
How to go to the BIOD set up
When I boot the computer I get the message "DMI Event Log Space Full. press FI to proceed. From your web site, i came to know that I have to go to the BIOS set up to rectify the problem. I have tried hitting various keys while booting such as "Esc., F1, F8, F12, Delete" but it didn't help. Kinldy give me the solution.
  • Mandeep  Singh
    Mandeep Singh May 11, 2010
    If you could give the manufacturer and model number for the computer it would be helpful. Secondly , if you tell if its a desktop or a laptop.
    You can try soft resetting the motherboard.
    1. Disconnect on cables from the back of the system tower (if its a desktop)
    or Disconnect Ac power adapter and remover battery(if its a laptop)
    2. Press and hold the power button for 10 seconds
    3. Reconnect the monitor cable, keyboard cable back to the tower(if its a desktop)
    reconnect only the ac adapter if its a portable
    4. Power on the system and check if you have the same error
    Thanks
    proton
    Scholar:
  • 145 Answers
This is a feature of the BIOS.
You need to enter the BIOS setup screens to fix. When you boot the computer, watch for the message "Hit Delete to run setup" or something similar. When you are able to get into the BIOS screens look for and advanced tab, then look for the DMI feature. You should be able to delete the contents of the log from there.
Good luck
Posted on Mar 12, 2009
  • 21 Answers
1. Restart your computer and while its powering up , keep pressing DELETE Key on the keyboard, this will take you to the BIOS screen.
2. Go to Advanced Setup, find the DMI logs option. This option may be located under different menus under different types of BIOS interfaces.
3. Once you locate the option, Select the option to Clear the DMI logs and also disable DMI logging if you don’t need it.
4. Save changes and exit from BIOS. Restart you computer.
Error message 1324. The path My Pictures contains an invalid character. Version 2.5.2.36 Can I remove? Can I update so my Quickbooks program can update? Need help please!
There are 3 possible reasons why you are getting this error message:
1. An invalid character in QuickBooks installation path.
2. An incorrect path setting in the Windows registry.
3.Insufficient hard drive space available to install the QuickBooks program.
To fix this problem, please do the following:
  1. Restart your computer, and reinstall QuickBooks.
  2. Confirm that at least 2.5 GB of disk space is available for installing QuickBooks (Quickbooks 2010 requires 1.5GB of disk space):
    1. Double-click the Computer (for Windows 7 or Vista) or My Computer (for Windows XP) icon on your Windows desktop.
    2. Note the amount of free space shown in the window next to the drive letter where QuickBooks is being installed:
      • If the amount of free space is less than 1 GB, free up disk space before installing QuickBooks or install QuickBooks on a different drive.
      • If the amount of free space is greater than 1 GB, proceed with step 2.
  3. Remove invalid characters from the QuickBooks installation path:
    1. Right-click the Windows Start button and select Explore.
    2. Navigate to the path shown in the error:
      • If there are non-alphanumeric characters in the name of any folder in the installation path, right-click the folder and select Rename to remove them, and then reinstall QuickBooks.
      • If there are only alphanumeric characters in the installation path, proceed with step 3.
  4. Create a new user in Windows to rewrite any Windows registry settings that may be causing the error and log in as that user to install QuickBooks.
Note: You must be logged in as a Windows administrator or as a member of the Administrator group to add a new user.
If this solution does not resolve the issue, you can read discussions and post messages and questions relating to your issue on the Intuit QuickBooks Community site for free, or you can contact a technical support agent for additional guidance. Fees may apply.
Nov 30, 2012 | NTI Backup Now EZ
How can I channge event log if I can't enter set up with F2
if you want to get the event log and the error code
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
hope this helps
Jun 29, 2012 | Computers & Internet
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Computer fails to boot --screen says AMD Data Change Update New Data to DMI
Boot to bios and from there you can reset dmi log to default or disable. That error appear when some changes happened from your hardware configuration add or remove.
Mar 21, 2010 | Computers & Internet
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
This issue can be caused by any of the below reasons.
-Corrupt boot files on the computer.
-Settings for hard disk drive are not correct.
-Floppy diskette or CD in computer causing issue.
-Boot devices not set properly.
-BIOS corrupt or misc. setting not set properly.
-Connections loose or disconnected.
-Bad Hard disk drive or other bad hardware.
Solution:
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:\> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue attempt to reset the BIOS / CMOS settings to the factory or default settings.
If the computer has been recently moved or new hardware has been installed in the computer it is possible that a connection may be loose or even disconnected. Verify that the hard disk drive, floppy and CD-ROM cables are properly connected.
Bad hard disk drive or other bad hardware
If you computer continues to freeze at the DMI message after attempting all of the above recommendations it is possible that the computer may be freezing because of a bad hard disk drive or other bad hardware in the computer.
Before replacing any hardware we first recommend you attempt to erase everything on the hard drive and start over.
If you're unable to get to the point of re-installing the operating system it's likely your computer has a hardware issue and it's suggested that the hard drive be replaced. If that doesn't resolve the issue then have the motherboard replaced.
Oct 20, 2009 | E-Machines eMachines Desktop PC
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Can't boot from FDD after upgrading bios. to version p20
log in to the BIOD using the DEL button (most likely unless it says otherwise at the boot window), then you can change the boot sequence to have the FDD as the first boot drive.
Jun 15, 2009 | Computers & Internet
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
BIOS problem
Turn of computer re start and reset the BIOS through the motherboard BIOS Reset jumpers
Aug 08, 2008 | Gigabyte GA-6WMM7 Motherboard
Microsoft Windows XP Professional Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
