Dell Dimension 2400 series BIOS version A05 Message once computer is started: Secondary drive 0 not found Secondary drive 1 not found Strike the F1 key to continue, F2 to run the setup utility I have hit the F1 key and nothing happens. I have hit the F2 key and the same thing, nothing happens. The screen is frozen on this message. Any suggestions on what to do would be very much appreciated.
    Brigadier General:
  • 3,400 Answers
If just set optimal defaults in BIOS windows are not perhaps on the
drive you try to boot from.BIOS can have changed drive.
Posted on Apr 22, 2013
What's your problem?a way to turn the SATA ports to ON in the BIOS
You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
Apr 04, 2012 | Dell Dimension 4700 PC Desktop
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dellgx150 i need to reset the bios settings back to default how do i do this?
Go into your BIOS by pressing F2 when you first turn on the computer. Try holding down the ALT burron and then press the F key and you should hear a beep. This will tell you that your BIOS has been reset back to the factory defaults. Then press ESC and exit saving changes and you'll be good to go.
If you need more help, feel free to let me know.
Jul 08, 2009 | Dell Dimension 2400 PC Desktop
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Secondary drive 1 not found?
It might be the CD Rom drive. Does it turn on though?
Enter the BIOS and check if all the peripherals are working.
Apr 01, 2009 | IBM ThinkPad T20 2647 Notebook
When I turn on my desktop computer it takes me to: Dell System Optiplex 170L Series BIOS Version A05 Secondary drive 0 Not Found Strike F1 key to continue F2 to run the sep up utilities When I strike F1...
this means that some drive is there in bios, but its not able to find it. go to the bios menu and check, if its there then disable it and FYI you computer not going to Crash, it will keep function, not finding one drive does not make any difference, just some issue with BIOS configuration.
Mar 24, 2009 | Dell OptiPlex GX270 PC Desktop
Hi there.
Sounds like the boot order has been changed in the bios.
The secondary drive sounds like the CD drive as most laptops only come with 1 HDD installed.
Change the boot order to the primary drive by Pressing F1 during startup when the ThinkPad logo is displayed..
Once in the bios change the boot order, save and exit, the computer will restart and boot from the hard drive, when you get into windows check to make sure that the CD rom recognizes CD/DVD's.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | IBM ThinkPad T20 2647 Notebook
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
David Payne
David Payne
