Question about Miele W864 Front Load Washer
Not heating - main wash light flashing
Machine still works - I just add hot water with the pwder. Local repair engineer says the heating element is okay. He suspects the problem is heater relay and suggests I go to Miele. Miele will only give me costs for temperature sensor and heating element and that is what they would bring out to the job. They won't give me a cost for heating relay / control board. If it is the heating relay it sounds as if it would mean a further visit with costs escalating - any suggestions welcomed!
  • 70 Answers
SOURCE: Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Posted on Jul 26, 2008
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
caroldon
  • 17130 Answers
SOURCE: Miele wt945 won't heat when washing
Possible that the heating element is faulty. It is best to confirm using a multimeter to test the continuity of the element. If so then check the voltage on the element at the time of the cycle and if there is no voltage then the controller unit is faulty. check for fault in the connectors , wires or links.
Posted on Jun 06, 2012
  • 389 Answers
SOURCE: how to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Posted on Sep 27, 2012
Machine stops and turns off soon after water fills
it could be that your heating element has a short circuit, as the water fills it reaches the exposed element and shuts off, I would call the local washing machine repair person for a quote eric
Jan 16, 2018 | Washing Machines
Washeing machine not heating up
It sounds like either the cable's have rusted off, fallen off the water heater element. Or the Water heater element has failed.
Watch this link to get the repairs done
How to replace washing machine element on Hotpoint washer
Mar 04, 2014 | Hotpoint Washing Machines
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
DWH B10 F3 - no heat. Stops at rinse and beeps + flashes 3 times
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Whirlpool Dishwashers
No hot water, checked ohms on both heat elements,top is 13.8 bottom is 13.4. i have 122volts to both elements and i played around with the heat adjustment on both top and bottom. over time could rusty well...
Marathon elements are specific to that water heater and can be ordered online, but generally are not at the local hardware.
Good to keep a couple spares around.
Marathon is 240Volt water heater.
Thermostats turn off one leg of the 240Volt circuit, so elements and themostats will always test for 120volts.
You removed wires off elements and tested each for continuity and tests showed elements to be good.
Test top two screws of upper thermostat and make sure you are getting 240V to the water heater.
If water heater has some hot water, then that says water heater is getting 240V, upper element is good, and remaining suspects are bad thermostats, bad lower element, or sediment build-up, or combination.
Open following link for troubleshoot run-down:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Water well.
If you have sediment build-up that reaches lower element, then water does not circulate around the element and water heater no longer heats very fast or accurately. If sediment is the problem, sooner or later the lower element will burn out.
Doesn't hurt to flush out the tank now and then, and vacuum out the sediment if that is problem.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Jul 10, 2011 | Rheem MR105245 Marathon Electric Water...
Limited hot water from 62 gal ge model D03666 looking for type and how to replace heating elements
Open following links to get started.
If water heater has NO hot water, then best suspect is ECO reset button tripped on upper thermostat. Open upper cover and push in red reset button. If reset keeps tripping, I usually replace both upper and lower thermostat.
If water heater has some hot water, then upper element is good so test lower element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | General Electric GE SmartWater Household...
I've had to reset it 2-3 in a week and tried to lower the temp but it still kicks out the reset button.
Good news is tank-type electric water heater if fully repairable by homeowner.
And you can reset water heater as needed until repair is made without damage.
-Tank is tripping reset so you can eliminate circuit breaker and electricity as suspects.
-Tank is not leaking, so TP valve is ok and tank not rusted out.
-Water pressure is fine so outlet and inlet pipes are not clogged with sediment.
-Tank is not short of hot water so you can eliminate leaking faucet as the problem.
-Tank is not short of hot water so lower element is not burned out due to sediment-build-up.
That leaves 6 suspects:
1) Loose wire at thermostat causing arc and overheating: Inspect thermostats and elements for signs of high heat and burning. Tighten screws very tight against copper wire.
2) Upper or lower thermostat is bad: replace both thermostats for $28. Buy generic thermostats at hardware or home center.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Element is shorted to ground in center of element: test elements
4) Stacking: read about stacking.
http://waterheatertimer.org/Stacking.html
5) Factory-installed cover and insulation have been removed from tank. Check that insulation and cover are placed back over thermostat each time so thermostat not exposed to cooler air that will cause overheating.
6) Combination of more than 1 suspect: do full troubleshoot:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 13, 2011 | RELIANCE ELECTRIC WATER HEATER
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Basic info on Rheem
Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
606 electoric little or not hot water
Reliance 606 240Volt water heater.
This water heater is fully repairable by homeowner
You have some hot water so that says upper element is good.
It also says electricity to water heater is good.
Also your reset button is not tripped. water heater is not overheating.
And covers and insulation are installed properly on water heater.
Water pipes are not clogged, and tank is not leaking water on floor.
Here are the suspects:
1) Leaking faucet or TP valve is running hot water continuously. Check for leaks.
2) Loose wire/ bad wire: remove covers and check for loose wire and signs of high heat and burning.
Also do full troubleshoot:
3) Bad lower element, possibly due to sediment build up: Test element.
4) Bad upper or lower thermostat: Replace both thermostats for $28.
Jan 31, 2011 | Reliance Water Heaters
Miele W864 Front Load Washer Logo
65 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
