Question about Panasonic DBS Battery Backup Unit (VB43130X) UPS System
NEED UPS FOR MY DBS576
I have a single cabinet Panasonic DBS576 phone system. I need to get a UPS to keep this unit up for at least 30 minutes or more. I need to know the power consumption fo this unit. Please help.
    Problem Solver:
  • 9 Answers
Tony166, according to the web, the Panasonic DBS 576 single cabinet phone system will run at a peak wattage of 360 or 3.3 amps. 3.3 amps x 120V = 396 VA.
Also, this is a very sensitive device and needs good clean power to eliminate frequency variations and line noise. You should put this system on an On Line or Double Conversion UPS. Not a Line Interactive or an Off Line unit! Those are the 3 UPS industry standard technologies. The Off Line technology is simply a battery in a box. It can break down a clean sinewave input and feed your connected load a stepwave signal. The Line Interactive unit will provide a sinewave while on battery power, but not during normal operation. Only a true On Line UPS will provide pure sinewave power 100% of the time!
I would suggest at least a 1kVA or 1.5kVA Liebert GXT2 product!
Contact www.ropeconsulting.com for a quote!
Posted on Mar 13, 2009
I want to remove all features on Panasonic KX-TT731
An expert can disable and reprogram your system in less than an hour. (ie 30 minutes or less) or you can try to do it yourself. It all depends on what answers the phone to start. If it's DISA, or ESVM, then you have to do it from progrqamming. If it's an external voice mail plugged into jacks 07 and 08 or 15 and 16, you can unplug it, but you still have to access programming to change the ringing. From the phone connected to jack 01 (usually extension 101) you need to get into programming and dial some codes.
You do plan on finding a manual first, don't you?
The system is probably a TA-824, part number which appears on a silver tag on the system cabinet.
Carl
Jul 27, 2012 | Panasonic Lands Phones
I have mge galaxy 3000 single unit 30 kv who shown those messages: defaut refroidissemt defaut temp batterie thank you for you help
sounds like you have a battery in thermal runaway. That means your battery could catch fire. I don't know what refroidissemt is. Your spelling is wrong. Go back to the UPS and write down the right alarms. Then I can help you.
Sep 24, 2011 | MGE Galaxy 3000 UPS System
I want a ups system for a PLC (programable logic control) panel, that shall be installed in the steel factory. Do you recommend this type of UPS system? Is it suitable for industrial environment?I need 30...
Is this going to be a true online UPS or a line interactive UPS? keep the UPS is a cool semi dust free place.77 degrees is perfect. Never put anything that uses a motor or compressor. This will overload the UPS. The UPS you are wanting to get is a off brand UPS and getting parts or tech. support may be hard. APC, Powerware and Liebert are good quality systems. You can contact me at ericpettingill@hotmail.com
Sep 20, 2011 | Opti DS1500B UPS System
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
I keep getting a system busy, try again later message when I try to place a call. I tried an old phone in the same jack and it works fine.
This is a COMMON problem with this handset. There are only few tricks that you could use to resolve this which are mentioned below :-
1. Unplug the unit for few minutes, say 15 minutes and then turn it ON.
2. De-register and re-register the phone.
3. Pull out the battery. Then hold the locate handset button on the base for 4 seconds.The base would beep for around 30 seconds and could resolve the problem.
If the problem persists, you need to send the unit for repair.To be honest, i would afraid to send the unit for repair as the repair cost would be high as compared to cost of the set.Buying a new set would be a much better and wise option.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Panasonic KX-TG1033S Cordless Phone
Panasonic kx-t7630. PABX lines have been reducede from 5 to 3. how can re assign CO buttons? now line 2 and 5 are no more in use, but still show as free. And if I press usual 9 to get outside line it...
If you know how to do system programming, the best thing to do is to move the lines into the first 3 positions on the cabinet and go into system program 600 and reduce the lines to 3. Your system installer or manager may be able to do the programming in less than 30 minutes.
Carl
Oct 21, 2010 | Panasonic KX-T7630 Corded Phone
9150 need to extend the full load run time to 60 minutes what do I need and how much
Here is the documentation page for the 9150: http://powerquality.eaton.com/Products-services/legacy/9150-info.asp
The 9150 had a couple of different Extended Battery Cabinets for longer runtimes but the 9150 was discontinued so I suggest you reach out to Eaton's service department.
1 800 843 9433
E-mail: LargeUPSTS@Eaton.com
Jul 08, 2010 | Powerware Series 9 9150 UPS System
New batteries in Smart UPS 700 only lasts 2 minutes at 30% load
If you blistered your older batteries a good chance your inverter is going or will go bad. The heat alone can do damage to your components. Time to replace the unit and remember next time not to wait so long to replace your batteries. Replacement of batteries every three to approaching four years is a good idea.
Oct 16, 2009 | APC Smart-UPS 700VA UPS System
Panasonic tvs-100 voice mail beeping and flashes red power light four times
I'm having an issue with the same unit. But the blinking light is NOT on my phone it's the power light to the actual unit in my server room. It will flash 4 times and then stop. Flash 4 times again... I have looked through the manual to see what 4x power light means and I have found nothing!
Jun 21, 2008 | Lands Phones
All Led's keeps flashing in the battery charge bar graph after replacing batteries.
just remove the battery again & dont put it back till 30 minutes then connect ur batter again.
Dec 27, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Computers & Internet Logo
82 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
