Question about 474L Avital 4Button Transmitter 434 MHz 266 Codes
Remote trunk release
I just bought a used 2007 scion that has this remote and it does not open the trunk or the alarm doesnt chip. Where can I get help or a manaula for this?
Is there a trunk release button inside the car?
New Member - Trunk release question - Nissan Forum ' Nissan Forums
forums.nicoclub.com/new-member-trunk-release-question-t320939.html
Mar 12, 2008 - I had a question regarding installing a trunk release. Since there is noneinside the car, a key is necessary to open the trunk. ... Hit the unlock button on the key fob twice (to unlock all the doors) and as EV says, walk over and press ... So thereis no way to open ther versa HATCH without the the key remote? trunk release inside the rogue?
Apr 18, 2009
I found the Trunk Button!!!
Sep 13, 2008
Anyone got Trunk release button on his remote ?
Aug 22, 2008
How do you open the hatch from inside?
Sep 13, 2007
More results from forums.nicoclub.com
2015 NISSAN Versa Sedan - Trunk Release - YouTube
? 0:37
https://www.youtube.com/watch?v=cE1SOFs_Tc4
May 5, 2014 - Uploaded by Nissan USA
2015 NISSAN Versa Sedan - Trunk Release. Nissan USA ...From inside the vehicle, pull up on the open lever. ? Unlock the trunk using the key. ... Press and hold the trunk button on the Intelligent Key. Please see your ...
Jan 19, 2016 | Thule 2010 Nissan Versa - Hatchback - Base...
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Is there a release trunk button inside the car?
Apr 18, 2009
Sep 13, 2008
Aug 22, 2008
Sep 13, 2007
? 0:37
Jan 19, 2016 | Cars & Trucks
Trunk will not close
check that latch is releasing when using remote. remote uses a cable to pull latch and cable may need to be lubed causing the latch to stick open. Let me guess if you slam a couple times it will latch, lube the actuator cable and latch well. hope this helps
Jul 17, 2014 | 2007 Toyota Camry
My trunk is stuck closed, Its not the remote it is the latch.. What can I do to get my trash out of the trunk and to make sure this doesn't happen again?
DO YOUR REAR SEAT LAY DOWN? IF SO YOU CAN GET IN THE TRUNK AND EMPTY IT OUT AND USE A LIGHT TO SEE IF SOMETHING IS CAUGHT IN THE LATCH...NOT SURE IF YOURS IS NEW ENOUGH TO HAVE A RELEASE INSIDE THE TRUNK BUT MAY HELP YOU OPEN IT
Dec 05, 2012 | 2007 Buick Lucerne CX
Keys locked in trunk of 2007 eclipse spyder convertible
at trunk button override and jump switch if dont work have to make way to get through at back seat
Aug 05, 2012 | 2007 Mitsubishi Eclipse Spyder GT...
I have 2007 kia the doorlocks are locking on there own when you open passenger door and make noise plus tpms light is on since my sensor was replaced after I bought new tires
TRY THIS PRESS REMOTE TRANSMITTER LOCK BUTTON ACTIVATES ALARMS AND LOCKS ALL DOORS.NOW PRESS REMOTE TRANSMITTER UNLOCK BUTTON DEACTIVATES ALARM AND UNLOCKS ALL DOORS AND TRUNK LID.IF VECHICLE UNLOCKED AND DOORS OR TAIL GATE NOT OPEN WITH IN 30 SECONDS LOCKS AND ALARM ARE REACTIVATED.IF YOU STILL HAVE TROUBLE WITH DOOR LOCKS THE DEALERSHIP HAS TO FIX.
Feb 15, 2010 | 2001 Kia Sportage
The alarm does not beep when remote is pressed scion tc 2006
Hold down the lock button for about 5-10 seconds
May 10, 2009 | 2007 Scion tC Coupe
2005 Nissan Altima trunks opens by itself
sounds like your remote. the trunk button is stuck on it can you pop the remote open and se if the button is stuck on the chip
Nov 20, 2008 | 2005 Nissan Altima
Programming an automobile keyless security remote
Have the same remote, just bought a 2000 astro cargo van with one of these, but no clue on how it works,, Would appreciate any info like model number of unit it self so I can possibly down load the owners/user manual.
Thank.
Nov 16, 2007 | Car Audio & Video
474L Avital 4Button Transmitter 434 MHz 266 Codes Logo
16 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
