Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
The wire is getting stuck between the welder and the gun. it gose in for a couple feet then stops. how do you fix this problem
  • rufusmcgee Mar 13, 2009
    i cut the piece of wire and pulled it back out. then i put it along the side to see how far it went. then i cut the casing to reveal the liner. it is not kinkned. i tried holding the whole thing striaght so it had a straight path. but it still stoped at the same spot. also tried difrent wire feed speeds but kept geting stoped.
  • rufusmcgee Mar 16, 2009
    i blew the wire out with air through the nozzel and there was a one inch size peice of wire that came out. it must have brock off some time. works fine now.
  • 92 Answers
Check the liner, if "kinked" replace.
Posted on Mar 12, 2009
    Problem Solver:
  • 19 Answers
That is normal, that is just the wire hanging up before it goes into the gun, try turning the wire speed all the way up, hold the trigger in and move the gun in a circular motion, if you keep the gun moving that will keep the wire from hanging up in one spot. i hope this helps
Posted on Apr 21, 2009
Why does wire keep coming out when trigger is not pulled
From the mig welder, unplug the trigger leads that exit the mig gun on the end of the gun that connects to the mig welder and power on your machine. If the wire flow stops, you have a shorted trigger circuit inside of the gun cable. If it doesn't stop wire flow, depending on your machine make & model, there is an internal issue with the trigger circuit that could possibly be just a simple relay issue.
Dec 25, 2014 | Welding Tools
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Wire stuck in gun
first off you need to give more information than wire is stuck in gun, you also need to tell what kind of gun, is it the one that came with the machine, if it is, did you try to take the whole gon off of the unit, it would be best to take the unit back to the place that you bought it from, there they have a service man who will fix it for you.
Mar 06, 2011 | Lincoln Electric Welding Tools
My wire feed is not working. there seems to be a crimp in the line leaving the welder. what is the best fix?
If the "line" leaving the welder is the weld gun the crimp could be that the liner in the gun lead is indeed crimped. This will not allow the wife to feed from the gun.
Remove the gun from the welder and see if you can push or pull the flux wire in/out of the gun. If you cannot then remove the liner and replace it. If the crimp is too bad you may not be able to evem remove the liner.If that is the case yo may have to replace the gun. Hope this helps.
Oct 18, 2010 | Firepower Flux Core Wire Feed Welder 88...
Having problems with wire feed of Mig 175 any tips to correct issue please?
Need more info! Slipping not enough tension!
Balling up wire in welder: Pinched liner in gun!
Jerking: Tension of spool too loose!
Here are a couple things to check for!
May 16, 2010 | Welding Tools
Wire stuck in liner and can not get out
if the wire is stuck in the liner, screw the top pieces off the gun, like the contact tip and the diffuser so you can grab the wire with pliers, pull the wire out of the liner with the pliers, make sure the back of the wire is not still connected to the spool!
Apr 11, 2009 | Clarke Power Products Clarke 130EN...
Stuck
You need to purchase new tips. They go bad after awhile. They're made of copper, and are quite soft. Simply remove the nozzle (piece covering the tip)by unscrewing it, then get a good set of pliers on the tip to unscrew it. When screwing the new tip in, be sure to only finger tighten it, if you put too much force on it with pliers and what not, you can damage the softmetal, and end up with the same problem.
Oct 16, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
537 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
