Question about Ryobi Tools & Hardware - Others
MY ORBITAL SANDER HS-335 DOES NOT SWITCH ON AT ALL
RYOBI ORBITAL SANDER MODEL HS-335
stug_57u
  • 99 Answers
SOURCE: orbital sander
You should really take it back to place of purchase and get it replaced/fixed under waranty. If you try anything other than checking the fuse you will invalidate the warranty. Most manufacturers allow retailers to replace faulty tools within seven days of purchase. Be sure to take your receipt with you as a copy will be needed for the shops warranty claim.
Posted on Nov 01, 2008
comax
  • 154 Answers
SOURCE: Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
Posted on May 05, 2009
  • 384 Answers
SOURCE: orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Posted on Jun 12, 2009
  • 226 Answers
SOURCE: black and decker model 7404 1/3 sheet sander - not orbiting
I read elsewhere of someone using JB Weld to fill in the pentagonal hole in the bottom plate, after coating the armature of the motor with a light coating of oil to keep the JP Weld from sticking. Assemble, and set aside for the JB Weld to set up.
tom
Posted on Jul 13, 2010
SOURCE: My porter cable orbital sander, model 333 needs to be lubricated
how to lube sander
Posted on Jul 12, 2011
Ryobi problems
This is not that bad of a problem we should be able to resolve this-
bring a lamp or radio which ever one you have used and know it works plug it into the wall outlet if your lamp or radio work then we know its the plug, now plug in yr Ryobi random orbital sander it should work to do not involve an extension cord while we are trouble shooting if neither have worked on the same plug you must have a 3 way light switch on the wall that needs to be turned on, try and slightly spread the the metal blades on yr Ryobi outward for a better contact between cord blades and wall plug make sure you have firmly pressed in the the on off switch.
Ryobi tests all of its factory reconditioned power tools before they are sent back to be sold in stores to the public...
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Parts for a 335 sander (6
Part is no longer produced. I am going to adapt a 6" dewalt pad by drilling new mounting holes. (The Dewalt pad has 4 holes.)
Jul 18, 2012 | Porter Cable Tools & Hardware - Others
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
Orbital sander doesnt orbit!
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
I have a ryobi belt sander EBS81321K Serial no 048911. The switch has developed a fault. Could you please advise where I can get a replacement & what would the cost be
Is that a BE321VS belt sander? I'm not getting any hits on that number you listed, and Ryobi is a little picky about what model number you use to search their parts database...
If it is, try this link to see a page where you can access a parts list. http://www.ryobitools.com/support/parts_batteries
Click on the button to go to the Power Tools Parts Store, then click Repair Parts Catalog, then agree to terms and enter the catalog page. Select the Model tab, type 321 in the box and press Search...
That brings you to a page listing the BE321VS sander.
Select Illustrated parts list and click on belt sander. This will open the parts view. From there you can scroll down to see if that is in fact your sander, and if so, scroll down to part 23, and select the switch (#760390001) and add it to your cart. Now close the window with the part view, and navigate back to the page titled "Ryobi Electronic Parts Catalog" (a tab on your browser), click on shopping cart at top, and when that opens click on the button to proceed to checkout and enter your info and pay, etc.
The cost of the switch is $4.44 USD. This web site will only ship to a street address in the US, so let me know if you reside elsewhere....
Mar 27, 2009 | Ryobi Tools & Hardware - Others
Tools & Hardware - Others Logo
29 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
