Question about Dell Dimension 8200 PC Desktop
Dell Demision 8200 just beep
My computer just beep, no screen or monitor play.it would beep 5 time 1, 2and 3 then stop.
  • Anonymous Mar 15, 2009
    My Dell Dimension 8200 only beeps 5-2-2-1 no screen, I have 2 sticks of samsung 256mb rdram that are new, the hard drive is new, I am trying to reinstall XP,I also get light codes A yellow B yellow C green D Green even if the memory is not installed the same results.
  • Milo Batiste Mar 29, 2009
    I did have a loose memory Module Thanks
  • Dell Master
  • 1,183 Answers
Kindly follow the troubleshooting steps on the following steps
http://tinyurl.com/dgb5x5
Chances are that you have a loose memory modules
Thanks
Proton
Posted on Mar 12, 2009
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Sep 18, 2013 | Dell Computers & Internet
Dell 8200, xp. plug & play config error. can not bring up ms xp. disconnected everything except keyboard, mouse & monitor.
Plug and Play Error? Check and see what CD/DVD Device you have connected. An 8200 uses Either SATA Connectors or IDE (WIDE GRAY CABLE) to connect to the hard disk and the Optical Drives. You may also want to check the jumper settings on the CD/DVD Drives. You will see if it's been set to "Cable Select," which is AUTO for most Dell computers. Dell OptiPlex and Dimension computers can be tricky so try "Cable Select" first. If you have TWO cd/dvd Drives in the PC, you have to have one SET for "master," and the other one to NOT HAVE A JUMPER AT ALL. Dell computers just work weird that way.
Sep 17, 2013 | Dell Dimension 8200 PC Desktop
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
4-3-1
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
1-1-3
NVRAM
1-1-4
1-2-1
1-2-2
1-2-3
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
3-4-1
3-4-2
3-4-3
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-3
4-3-4
4-4-1
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
"my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Mar 14, 2009 | Dell Dimension 8200 PC Desktop
My computer crashed and when i turn it on, there are 2 beeps
Here are the beep codes for Dell. Count the beeps sequences and compare them to the list.
Dell BIOS Beep Codes:
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Jan 29, 2009 | ViewSonic VA1703wb Monitor
Dell Monitor (e171fpb) is black
Try checking your connections, and also restarting your computer with the monitor plugged in. If you've made any internal changes to your computer, back them out one at a time restarting each time until your monitor works. If you hear any beeping or still can't get it to work, let me know
Let me know if this helps
Jan 06, 2009 | Dell Dimension 8200 PC Desktop
Wont boot just has series of beeps
Table 2. System Beep Codes
Beep Code Possible Cause Corrective Action
1 Memory refresh failure Reseat the DIMMs.
2 Parity cannot be reset Reseat the DIMMs.
3 Memory failure within the first 64 KB of memory Reseat the DIMMs.
4 Timer not operational See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
5 Processor failure See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
6 8442 keyboard controller error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
7 Processor exception error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
8 Video display memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
9 Optional ROM checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
10 CMOS memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
11 BIOS checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
Jan 11, 2008 | ASUS K8V-MX Motherboard
Dell Dimension 8200 PC Desktop Logo
271 people viewed this question
Alun Cox
