Question about Saws
Blade stuck can;t get nut off
  • 843 Answers
Two key tricks-- use a block of wood to keep the blade from turning,(you might need three hands) and turn the nut in the direction that the teeth of the blade are pointing.
Posted on Apr 24, 2013
Remove pulley from mower deck blade shafts
take belts off, loosen big nut on top of shaft, leave that big nut on the shaft just a few threads then take a hammer and tap on that nut to loosen the shaft from the bearings, take nut off then the shaft should fall out, if your bottom bearing is stuck on the shaft itself its gunna be fun to take that off, but if it didn't get stuck then take a punch and hammer to the bearings go thru the top to get the bottom one and vice versa, your gunna need a hammer for most of it, hope this helps its not that hard
May 20, 2015 | Garden
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My driver's side wiper blade has stopped working.
The nut that holds it to the wiper pivot is either loose or the pivot is stripped, try tightening the nut first.
Oct 05, 2017 | 2002 Pontiac Montana
Cannot loosen nut/bolt that holds blade. Had friend try it to with screwdriver in place to stop any movement of blade, he could not do it either. Nut has a spring like item directly behind it. ...
Hello, it is hard for me to explain this but it is simple:
there is a small button that you have to smash on it,
move the blade in any direction while smashing button
when stucks! it is ready to loose it, good luck buddie
Jul 02, 2011 | Saws
Is the locking nut on the saw blade left or right hand thread?
Almost always it's standard right hand thread. If your problem is that it's stuck, spray some WD-40 were the blade and the head of the nut meet and tap the blade with a piece of wood. This causes a slight vibration and allows the WD-40 to work under the head and onto the threads.
Sep 06, 2010 | Saws
Changing blades.To loosen the blades nut, which way does it turn?
hi. you dont say what make or model but I offer the following. if it's just a single bolt or nut holding the blade it will rely on a bellville type washer (dished ) or will be pegged either side of the nut or bolt, if the later try to drive the pegs down level with the mounting boss, now get a couple of friends to lift the whole deck so you can secure the nut or bolt in a vice (vise) and using both hands turn the blade itself the opposite way that you would turn the nut, this has never failed for me, if the blades counter rotate, one will be left hand thread the other right hand. bear in mind that a rotary blade spins at around 150-200 mph, every time you hit an obstruction (and you will) the blade will tighten particularly if secured with a belleville type washer. best of luck
Nov 28, 2009 | Garden
Grinder blade stuck inside skill saw cant get it out
Put your fingers behind the blade and pop the shaft with a plastic-headed hammer. You may have grinding residue that is jamming the release of the blade. Hope that helps!
Nov 25, 2009 | Saws
Stuck blade
I looked for a picture of this saw -- couldn't find one. When you wrote that you put the blade down on a 2x4 that sounds like a chop saw. In which case the balde is attached to the motor shaft.
A torch is kinda extreme, but if you do it safely & quickly it might work. If the blade is on the motor shaft, you don't want too much heat to get into the motor.
You don't want to heat the blade. Heat the nut only -- the nut will expand more than the shaft and perhaps break loose. I wouldn't heat it more than 20-30 seconds and make sure the flame is directly on the nut. Also make sure all flammable stuff is out of the way (like sawdust).
I wouldn't expect the heating to allow you take it off by hand -- you'll probably have to try all the brute force measures again -- and remember the left hand threads.
Apr 21, 2009 | Saws
Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Plz rate my solution.
Thabks.
Jan 10, 2009 | Smeg SE280X Stainless Steel Electric...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
