Question about Garden
Where is oil drainplug on a poulan 4.50 briggs an stratton engine
  • 2692 Answers
SOURCE: can't find oil drain plug on eager-1 mower
Disconnect the sparkplug andf ground it. Turn the push mower on it side and scrap away all the grass from under the deck and look for the plug. If you cannot find one, drain the oil out from  the fill tube into a pan, buy turning it onto it's side into the pan.
Posted on May 06, 2009
  • 376 Answers
SOURCE: need to know where to put the oil
There should be a plug with two ears on the left rear of the engine
Posted on Jun 02, 2009
  • 376 Answers
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Posted on Jun 12, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
smartr10U
  • 1305 Answers
SOURCE: what type of oil for a 650 series briggs and
B/S webpages show that they recommend a Synthetic 5w-30 oil for their small motors...
K
Posted on Aug 29, 2009
Where is the plug to change the oil?
Amy, if drain is not in the bottom of engine by blade, turn mower on it's side to drain oil to change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change your Briggs Stratton engine oil
Toro 6 5hp GTS Oil Change mpg
Mar 26, 2016 | Poulan Pro Pr550n22sh 22-Inch 140cc Briggs...
How much oil is needed for my Poulan Pro 550 lawnmower?
Briggs and Stratton call for 20 oz but warn to confirm the level with the dipstick reading.
Jun 11, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
What oil does a polan 38inch deck take
Check with Briggs and Stratton to confirm but, for summer use 10W30 or a straight 30 weight automotive grade oil will work.
Jun 01, 2014 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I bought a poulan pro 6.25 series with no manual please tell me the correct engine oil to use for a PR625y22RP engine please
I'm guessing you have a basic Briggs and Stratton engine, which is the standard on these machines (or a Tecumseh). The standard oil used in almost every mower on the planet is straight 30 weight oil (not multi-viscosity, such as 10W30). Just 30 weight. There should be a label on the side of the engine and on that label, it will actually be listed, but I'm going with 30 weight. For longer engine life, use synthetic oil. It will need less changing. Here is a photo off one of my Tecumseh's. You'll see it clearly states SAE 30 right there on the sticker. Hope this helps. knucklebstr.jpg
Jun 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Jun 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
