Question about Lifetime 71729 In Ground Basketball Hoop
Gas spring wont go back up - Lifetime 71729 In Ground Basketball Hoop
99 Dakota SLT v6 4wd harsh late shifting. Fix?
the valve body could have what they call varnish on it causing it to stick. there are also little springs in the transmission that assist in moving things, it is possible a spring broke
Apr 18, 2017 | Dodge Dakota Cars & Trucks
Gas pedal stuck open
lube-oil the peddle and cable-do both ends of the cable-check the return spring -it may be weak-you may want to replace it-cheers Denny
Nov 22, 2013 | Jeep Cherokee Cars & Trucks
Blower string wont retract
you might have installed the wrong spring type, check also the stopper or the lock inside that holds the spring secure.
Jun 04, 2013 | Garden
The pull string wont go back in on the weedeater
Likely the recoil spring has broken (often the end) or the plastic recoil winding in which the spring sets in has broken or worn to the point in which the spring will no longer seat properly. Complete removal is necessary to determine the problem.
May 27, 2010 | Craftsman 25cc Gas Line Trimmer
Pull cord wont pull
ok i assume it is a gas powered pressure washer, if the pull rope wont pull out at all you either have a locked up motor or pump if it is out and wont go back in or recoil then the spring under the engine cover has either broke or come unwound.also if it wont pull out do youhave water applied to pump? if so turn off water and disconnect water hose to relieve pressure and try to pull it then then if it starts then apply water.
Mar 18, 2010 | Garden
I opened my gas cap and now it just wont close
The gas cap or the gas cover?
If the cap wont go back on then I don't know whats going on there.
If you mean the COVER or fuel door, then I would say your cable release is gummed up and sticking. Get some WD and spray the latching point on the car and then push the door in and let it spring back a couple times..spray again and repeat.....do this until the door stays shut. Then the next time you are getting an oil change get the station mechanic to spray the latch with some white lithium or other approved lubricant.
good luck and be careful.
Feb 08, 2010 | 2007 Lexus GS 350 AWD Sedan
I can pull my string from a ryobi cs 30 and it wont go back
Either the rewind spring is broken or the starting spool is stripped. Either way you have to open up the entire unit. Check those two things and good luck...Lee
Oct 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Oven
The lock spring unhook back cover must open / gas must be shut down. before open back cover., spring might cut spring hook corroded possibility door door lock malfunction.
Jan 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
Lifetime 71729 In Ground Basketball Hoop Logo
201 people viewed this question
Top Lifetime Sport & Outdoor - Others Experts
Vernon Taylor
michael vanier
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
