Question about Car Audio & Video
I am replacing an 02 sensor on a 2000 Honda odyssey. It is bank 1 sensor 2 I am looking for.
    Sergeant:
  • 290 Answers
Yes that is the correct O2 sensor that you showed in your video i am enclosing a video to help you.
Posted on Apr 22, 2013
  • darla_yw Apr 23, 2013
    Thanks. I replaced my sensor. So far no check engine light. I am glad. A pat on the back for me and high five to you for the info. ;)
Location of 02 sensor bank 1 sensor 1 of Honda odyssey
How many do you have O2 sensors front and back?
May 15, 2016 | Honda Cars & Trucks
2003 honda civic o2 how to replace And how do i fin out which once is it
Hi Jesus, Im AL the owner of Big As Auto Repair.
If you have a 4 cylinder engine then you will only have two 02 sensors 1/1 is upstream and 1/2 is downstream. Upstream is the one closet to the engine and downstream is the one farther away from the engine.
If you have a six OR eight cylinder engine you will have four 02 Sensors. 1/1 means Bank One Sensor One. 1/1 and Bank one means right bank and right bank means the side with the number 1 spark plug. SO, 1/1 means, "Right Bank" Upstream 02 sensor. 1/2 means, "Right Bank" Downstream 02 sensor.
2/1 means, "Left Bank" Upstream 02 sensor and 2/2 means, "Left Bank" Downstream 02 sensor. Hope this helps and please visit my auto-repair-website at: http://www.bigasautorepair.com/
Nov 26, 2015 | 2003 Honda Civic
What is a bank sensor for a honda civic ls 04
O2 sensor bank 1 sensor 1 should actually be read as: O2 sensor, bank 1, sensor 1. Meaning the first oxygen sensor (O2 sensor #1) on cylinder bank #1 (it's a Honda inline 4 -cylinder engine, so it only has one bank of cylinders; a V6 or V8 engine would have tow banks arranged in a V shape) needs to be replaced. The oxygen sensor will be threaded into the exhaust near where the manifold (or possibly threaded in at the manifold itself) with some wires coming out of it. In the photo, the O2 sensor is labelled as the air/fuel ratio sensor. 5478b94e-7fcc-4726-9bba-653a172e5a92.jpg
Jun 23, 2014 | 2000 Nissan Frontier
Look on the exhaust manifold just before it connects to the exhaust at the doughnut gasket
Apr 12, 2014 | 2003 Honda Accord
What is the location of bank 2 sensor 1 2006 honda odyssey
It is before the catalytic converter in the exhaust pipe, on the side of the engine with cylinder number two.
Apr 12, 2013 | 2006 Honda Odyssey
I just changed the o2 sensor bank 1 sensor 2
Well, FIRST let me ask you what does B1S2 mean to you?
Bank 1 means it is the same side as the #1 Cylinder
Sensor 2 means it is the Sensor DOWN STREAM or AFTER the Catalytic converter..
With this being said... Are you sure you changed the correct O2 Sensor?
The Second thing that I need to tell you is this... Because it says O2 Sensor. Majority of the time it is the Sensor, but it could be other things... Broken Wire, Computer, Fuel Pressure and if it is DOWNSTEAM... Then it could be the CAT.
THEN.... I looked up and see that it was a HONDA and low and behold it occurred to me...
WHERE DID YOU GET YOUR O2 Sensor From? (this is where I saved so many people)...
Honda has made the variables so TIGHT that an AFTERMARKET O2 Sensor does not work....
If you have a ULEV Vehicle (Ultra Low Emissions Vehicle), you are pretty much forced to get the Sensor from Honda....
That would be my FIRST GUESS.... Get the HONDA Part...
Apr 05, 2013 | 2003 Honda Odyssey
I need to change a honda odyssey bank 2 sensor 1 sensor
First let me say the odds of the sensor being bad are 50/50. The trouble code would tell you the sensor is not reading correctly, not necessarily that the sensor has failed.
Bank two is on the side with cylinder number 2 and sensor one is in front of the catalytic converter.
Sep 21, 2012 | Cars & Trucks
What is bank 1 o2 sensor in honda odyssey 2005 ? FRONT OR REAR ?
O2 Bank 1 sensor is before the catalytic converter, is located just behind where the exhaust pipes from the front bank of cylinders and rear bank of cylinders join up.
The other sensor goes into the side of the catalytic converter, it is bank 1 sensor 2.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 11, 2012 | 2005 Honda Odyssey
Bank one cylinder one is where on a 2006 honda odyssey
bank 1 is the three cylinders toward the rear of the vehicle. Cylinder 1 is the cylinder on that bank which is closest to the passenger side. There are only two oxygen sensors on the vehicle. Bank 1 sensor 1 is just after the merge of the rear bank exhaust pipe with the front bank pipe. Sensor 1 is visible if you look under the vehicle from the front. Bank 1 sensor 2 is the sensor "downstream" or after the catalytic converter. Actually, it is stuffed into the side of the catalytic converter. There are only two sensors because with a single tailpipe, only one cat' is involved.
Feb 16, 2011 | 2006 Honda Odyssey
Honda Odyssey 1999 wher is located bank 1 sensor 1
The oxygen sensor for bank 1 sensor 1 is located just behind where the exhaust pipes from the front bank of cylinders and rear bank of cylinders join up. If you look under the car from the front and follow the exhaust pipes, it is the one you can see easily. There are only two oxygen sensors on the car---the one described above is bank 1 sensor 1. The other sensor goes into the side of the catalytic converter. It is bank 1 sensor 2.
Feb 08, 2011 | Honda Odyssey Cars & Trucks
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
