Question about Plumbing
Wood splitter slow action
I have an older Didier wood splitter. Nothing stops the hydraulic piston. However, it is extremely slow. Is there any adjustment I can make to speed up the ram?
  • 2,984 Answers
What's going on is the seals are worn out on the inside and the fluid is bypassing. This is why it is slow.....while operating it, feel it. If it is hot, it's bypassing....the actuator (cylider that houses the piston) needs rebuilt.
If you can get the specs on this, it is really easy to reseal....pressure testing is another thing....take it to a rebuild shop. get this done and it will last another 30 winters!
Posted on Mar 14, 2009
  • 3 Answers
If it's always been that way, it may have a single-stage pump. My Troy-Bilt PTO splitter was made by Didier around 1984 and has a 2-stage hydraulic pump. The cylinder return stroke is relatively quick.
Posted on May 05, 2009
Was working fine until just not enough power to split log
Air conditioners usually cannot split logs very well. They are better at cooling instead of splitting wood. If you have a wood splitter and picked AC by mistake then I would check the hydraulic fluid level, grease the slide that the splitter wedge runs on. Then change the oil in the engine and clean the airfilter or replace it. Also make sure you use fresh gas and not old gas. gas goes bad after sitting a few months.
Aug 15, 2015 | Heating & Cooling
I have a didier wood splitter and the hydraulic need seals. part number is 200889.where can i get the seals. here is my e mail .harleyman5787@hotmail.com
Most companies have a website that offers repair parts . You'll be asked to enter the model number and serial number to be sure to get the correct parts you'll need. Some websites give you a contact number where you can call them directly to order the parts that you want. Google the manufacturer name. That will put you on the right track. Good luck .Hope this helps you.
Feb 05, 2015 | Sewing Machines
Splitter runs through the cycle too slow
Make sure you hydrolic fluid tank has the proper amount of fluid.
Sep 11, 2014 | Swisher 28 Ton 11.5 HP Log Splitter -...
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Source:
http://www.qci.net/files/5_Ton_Log_Splitter_-_USE_THIS_MANUAL.pdf
Sep 22, 2013 | Hardware & Accessories
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
Ryobi electric log splitter won't return to startposautomaticaly
We have one of these splitters and the only problem has been a control valve sticking down. Oiled the valve button with silicon oil which seems to have helped. Be sure to close the bleeder valve when putting the machine away. We bought the machine from Home Depot. Use some headphones for your music! We have split rounds much larger than recommended by splitting from different sides. Hope this helps!
May 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Whay kind of hydraulic fluid do I use in a mtd split it wood splitter
You can use 10W AW hydraulic fluid or Dexron III automatic transmission fluid. It takes approximately 4 gallons. You need to change the fluid after every 100 hours of usage.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Mtd Heavy Machinery
WE HAVE A DIDIER WOOD SPLITTER AND NEED REPAIR PARTS. ANY IDEA WHERE TO FIND THEM? THE HANDLE TO RUN THE RAM IS BROKEN. WE HAVE BEEN TOLD THE COMPANY IS OUT OF BUSINESS. MODEL IS C-26A, PART NUMBER IS...
Well , i OWN a modified Didier ; 3pt and is selfpower now . MOST parts available from Tractor Supply . pumps , valves and so forth . Most any industrial hydraulic supply can get seals for cylinder , if it leaks.
Nothing quite like a Didier anymore.
Sep 28, 2009 | Saws
Plumbing Logo
1,373 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
