Question about Riccar 8955 Upright Vacuum
After changing the bag on my riccar it is very hard to push'
It used to run very smooth and was easy to push, not i really hae to work hard to get it to move on te carpet. There is nothing jammed on the roller
    New Friend:
  • 57 Answers
After putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Posted on Apr 22, 2013
SOURCE: Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
Posted on May 21, 2009
ukvacfan
  • 328 Answers
SOURCE: how do I find the opening to change the bag on the Riccar RC 1100
Just above the hole where the hose goes there's a squarish part to where your hand should go. It should just pull upwards.
User manual download (FREE and in pdf form:)
http://www.riccar.com/ftp/whitepapers/1100_OwnersManual.pdf
Posted on Jun 19, 2009
Vac Belts
  • 701 Answers
SOURCE: no suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Posted on Dec 30, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Riccar 8850 stopped running.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Posted on Mar 18, 2010
Testimonial: "Thanks for the information. I pressed the reset button and everything is working fine again."
reyjoshua07
  • 1157 Answers
SOURCE: My Riccar Vacuum cleaner just stopped working
Hi susanchri43,
Have you tried resetting the machine using the reset button on the back of the vacuum? If not please press the reset button. Here are additional troubleshooting steps that you may apply to determine what's wrong with it.
1. Ensure that the power cord is firmly in. You may also try to unplug and replug the power cord.
2. This vacuums are equipped with a thermal motor protection circuit that will shut the vacuum down if it detects excessive heat up. Overloading due to a clog, or the bag being full can cause heat up.
3. Check the hose pipe or the upright's mouth and remove any obstacles. Use a broom handle to poke any debris that may become trapped in the hose.
4. Unplug the machine and use your fingers to pull out any debris in the machine's mouth. Cut any thread or string that may have become wound around the rollers. Plug the machine back in and press the reset button on the back of the vacuum.
5. Switch the carpet switch to the "Carpet" position if you are using the vacuum on carpet and the vacuum won't pick up debris. Turn the tool activation switch to the "Off" position. Take a look at the light marked "Brushroll." If it's illuminated, remove the cause of the jam at the brushroll.
6. If the vacuum allows dust to escape, check if all the covers are tight. The filters and vacuum bag must be installed correctly. The filters snap into place and cannot be washed and re-used. Make sure the base of the bag collar is on the bag supports.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 04, 2011
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
Why doesn't brush roller rotate?
The brush roller may have been reinstalled incorrectly, i.e., not seated. The brush roller may be binding on the bottom plate or the bottom plate could have been reinstalled incorrectly.
Mar 20, 2016 | Vacuums
How do I change a riccar vacuum bag type z
Attach the bag securely in the bag holder. Slide the bag holder into the groove in the vacuum making sure the hole in the bag lines up with the hole in the vacuum where the hose attaches to.
Feb 10, 2015 | Riccar Vacuums
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
Where is riccar radiance filter reset button
Remove the bag door, you will see a little round rubber piece about 1/4 in diameter on the motor cover. Remove the rubber piece and very gently push the button while the brush roll motor is running
May 15, 2014 | Riccar Vacuums
N2000 clean filter
The red guard goes on top of the foam after it is installed. The purpose of the red guard is to keep the bag from sucking down against the filter when you get a few inches of dirt in the bottom of the bag. If it sucks down against the filter the dirt in the bag will cause an airlfow restriction even though the bag is not full.
Jan 25, 2014 | Riccar Vacuums
After changing he bag, it is very difficult to push my riccar upright on carpet
air has more space to go through, will be harder to use on carpet until some dirt gets into the airbag, it will be easier, but you will need to replace bag again
Apr 22, 2013 | Riccar Vacuums
Dyson 33 wont push on plush carpet
I'm sorry to hear you're having difficulty using your DC33 on this particular carpet. If you haven't already contacted our Helpline, I'd encourage you to do so, as we'll be able to discuss other options which may be more suitable for your needs.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson DC33 Bagged Upright Vacuum
Riccar 8955 Upright Vacuum Logo
208 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
