Question about ASUS RTN10 wireless router
The wireless is ok but if theres black out when the power is back my wireless is not working
  • ASUS Master
  • 7,627 Answers
First I suggest you get a UPS and attach ALL your devices on battery backup. Power surges/power interruptions could be detrimental to your electronics. After a Power Interruptions ALL your devices may have to be rebooted one by one, allowing each to selftest. If you live where the power goes off often or electrical storms are common, it's crucial to use Surge protectors and a Universial Power Supply.
Posted on Apr 26, 2013
The acer 5536 wireless lan communication button indicator isn't on and the screen is black.
try external monitor to laptop with screen disconnected ,if it works laptop ok screen has problem ,common problem blown fluro light or power to screen and power to fluro ok fluro has problem,check power to screen fluro nil then screen power supply problem or led check wire loom from case to screen power supply.
Sep 08, 2014 | Acer ASPIRE 5536-5883 COMPATIBLE LAPTOP...
Cant get my dell inspiron 1100 to recognize my modem after reinstalling installing xp system
Oh my goodness, who uses a modem? Please don't tell me you get on the internet using a phone line and modem.
Ohh Internet Modem as his first sentence says. I'm thinking that means he has a high speed modem from a internet service provider. Ok, I would suggest that you remove the power cord, remove the battery, turn the laptop over and find the cover that houses the wireless modem and remove the antennas (black and white cables) from the wireless card, then remove the wireless card from the slot. Now press and hold the power button for 30 seconds, then put everything back together and reboot.
Apr 09, 2012 | Computers & Internet
Suddenly network card stopped work. can't connect internet
Try This: Unplug the power to the DSL Router for 20 seconds then plug it back up. Remove the power cord and battery from the laptop, then press and hold the power button for 30 seconds. Turn the laptop over and look for the screw on the Wireless Card Cover. Remove the screw and the cover (it may be a number of screws depending you your system) then unplug the antenna cables to the wireless card (normally a black and white or black and gray cable). Remember which cable goes where before you remove them. Remove the screw that holds the wireless card in the slot, then remove it. Put the Wireless card back in the slot and secure it with a screw. Put the antennas back on the wireless card and then the cover. Put the battery back in, plug in the power cord and reboot.
If the system still does not find your wifi card, the card might be bad.
*** Sometimes the wireless card will be under the keyboard or palmrest instead of the bottom of the computer.
Apr 05, 2012 | Computers & Internet
My lexmark x4975 will connect by USB but will not connect by wireless. The help assistant asked if any lights were showing on the WI FI indicator - none are lit. How can I make wireless connection?
using your pc/laptop you will have to create a new connection an search for the printer when this has been done, make sure the printers wireless is enabled before attempting to create a new connection
May 03, 2010 | Lexmark X4975 Wireless Color Multifunction...
Wireless router not working all of the sudden
Reset your router, it would enable you to connect
On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Dec 12, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Power, Black screen, keyboard not working
It seems power supply ok...there might be problem inRAM..SO try to change the RAM...
Dec 16, 2008 | Acer Aspire 5610 Notebook
Hi I have a bluetooth V512 - it worked fine till now but today I cannot get it to stay on and it does no connect with my blackberry
ok heres the solution completly remove bt. from black berry and go threw a complete setup again
when setting up bb. looking for bt. hold bt. power button down till bb. recognizes it then it will ask for security code 0000 this will set you back up with your bt. again
Dec 05, 2008 | Computers & Internet
Computer Does not Boot correctly, Monitor is Black.
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Sep 27, 2008 | IBM Aptiva E 240 (2158240) PC Desktop
ASUS RTN10 wireless router Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
