Question about Duke 59-E3V 2401 Convection Oven, Half-Section, Single Deck, High Perf
The fan in my commerical duke convection over isn't spinning
It making a noise, but not spinning
  • 5 Answers
Maybe something is stuck in the fan, or you could check with someone
Posted on Nov 28, 2013
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
What wrong when a jenn air convection over fan make noise
What kind of noise? Has the type of noise it's making different now then previously?
Nov 19, 2013 | Jenn-Air Ovens
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
I moved my refrigerator to vacum (Frigidaire model PLHT217TAK 2002) and since then the warm air stopped coming out from the front bottom vent. It also stopped making noise, it seems to want to start but...
the condenser fan motor is what blows the air around down there,pull out the machine remove the back bottom panel and you'll see the fan,check it to see if something is stuck in the fan blade keeping it from spinning,do this right away,if the fan isn't blowing you can cook your compressor,if something is wrong with the fan motor you can leave the bottom panel off and stick a regular fan back there to keep the compressor cool until you fix the fan motor.hope this helps
Jun 23, 2011 | Frigidaire Refrigerators
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
My LG air conditioner does not blow air. The compressor starts properly (owing to the noise it makes)
There may be something in the fan or could have the bearings worn in the motor. If you're careful you can turn the unit to the off position, take the plastic front off, reach in thru where the air blows out and try to give the fan blower a spin and see if it is free. If it isn't, try to find whats holding it. If it is, the bearings are worn and you'll have to have a new motor.
May 11, 2011 | LG Heat cool Window Air Conditioner
Duke 59-E3V 2401 Convection Oven, Half-Section, Single Deck, High Perf Logo
739 people viewed this question
Top Duke Cooking Experts
Tom Chichester
ray gallant
Are you a Duke Cooking Expert? Answer questions, earn points and help others
