Question about Yamaha RX-V663 Receiver
Yamaha rx-v859 reciever keeps shutting off - Yamaha RX-V663 Receiver
  • 236 Answers
SOURCE: yamaha receiver model rx-v550
it is your protection circuit working, preventing the unit from any further damage to circuitry. you can check first your speaker cabling for any short connections, possibly red/black terminal wires got entangled. if all ok then try removing all speakers then turn on the amp. if still does the same thing turning off then you have a problem with the amp output stage, shorted power output transistrs/driver probably. if the unit turns on normal without the speakers then you must have one or both of your speakers busted. by the way this amp is multi channel, after removing ALL the speakers connected, and does not turn off anymore, put the speakers back one by one and observe if the unit with turn off and on which set of speakers. otherwise if still trips even without the speakers, it is your amplifier that is deffeective, any of the five channels, main, rear,center. let me know result so i can guide you on how you can get it repaired and what will be the extent of damage in case.
reden
Posted on May 22, 2008
SOURCE: Yamaha Reciever rx-v461
don't know
Posted on Sep 30, 2008
petraman7
  • 1175 Answers
SOURCE: yamaha rx-v461 not working
Does the reciever have separate speaker switches?
Try turning off the speakers and turning on the amp.
If it doesnt have speaker switches , make sure ALL the speakers are connected at both ends and try turning on the amp again.
Posted on Feb 04, 2009
  • 127 Answers
SOURCE: Is a yamaha rx-v465 supposed to recieved both
What connection do you use?
This receiver supports both video and audio over HDMI. It has also other video inputs, but it doesn't have any video processing.
So if you connect your equipment for example to component video in, its video output will be present only on component video out (NOT on the HDMI output nor s-video output).
Posted on Mar 03, 2010
  • 6771 Answers
SOURCE: My yamaha receiver RX-V363 keeps shutting off and saying check SP cable
It is one ot two things, the audio output transistors or ic,s are shorted, or the speaker wires in the back of the surround sound are shorting.
Posted on Apr 09, 2012
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Immidiate shut down
Your full of it, There is a internal problem with the reciever if it keeps on turnig off, If there was a power (Surge) Where you live will cause that problem.Your cheaper off just to get a (Different) Reciever then have it (Repaired,If there was a (Power) Surge.
Oct 04, 2012 | Yamaha RX-V995 Receiver
Apr 08, 2012 | Yamaha RX-V363 Receiver
Rx-v795a reciever shuts off after 5 min or more can not hear fan in reciever for cooling.
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 15, 2010 | Yamaha RX-V795 Receiver
Yamaha reciever model rx-v563 power cord
It's just a power cable. Get something like this
http://www.radioshack.com/product/index.jsp?productId=3875430
and lop off the end that doesn't fit, strip them and either splice it to the remnants or go inside and connect it to where the original goes.
May 05, 2010 | Yamaha RX-V563 Receiver
Not getting on yamaha av reciever rx-v363
IF IN WARRANTY SEND BACK FOR SERVICE...
Apr 04, 2010 | Yamaha RX-V363 Receiver
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Yamaha RX-V995 5.1 problem playing DVD's loudly
try using the analog mine had a problem with the dac. have any questions email me at facukoff@hotmail.com
Aug 13, 2007 | Yamaha RX-V995 Receiver
Yamaha RX-V663 Receiver Logo
192 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
