Question about Stanley Air Tools & Compressors
HAVE A SB-1850BN AIR LEAKS THROUGHT TRIGGER WHEN I TRY USE IT
WHEN I TRY USE BRAD NAILER AIR LEAKS AT THRGGER WHEN I TRY TO FIRE A BRAD
    New Friend:
  • 24 Answers
Replace the trigger valve,,use a roll pin punch to make it easier
Posted on Apr 27, 2014
  • 24 Answers
SOURCE: paslode framing nailer won't shoot
Take 4 bolts off of head . Clean and lube head valve with air nailer oil. Not wd40
Posted on Apr 14, 2009
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
wiringlunati
  • 576 Answers
SOURCE: central pneumatic air nailer leaks air around
Probably needs the trigger valve rebuilt/replaced. Contact Harbor Freight for replacement parts.
Posted on Nov 25, 2009
puertobori
  • 7733 Answers
SOURCE: my Makita AF 503 18 guage brad nailer leaks air
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Posted on Nov 04, 2010
  • 1388 Answers
SOURCE: Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer Logo Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer owner manual
Stanley Bostitch has been sold to Dewalt. The link below has all the information and parts for your gun. Good luck with your projects.
http://servicenet.dewalt.com/
Posted on Jul 21, 2012
How do I clear a jam?
Hi Gary:
SAFETY FIRST! Disconnect from air supply.
Pull trigger to make sure not "loaded"
- Here's what I would do.
1) Open magazine and remove stick of remaining nails
2) Try to remove jammed nail with pliers, pointy tool, etc.
3) Use allen wrenches to dis-mantle head until everything comes apart and jammed nail falls out.
4) re-assemble, cleaning and oiling at the same time.
Once done, re-connect to air supply and test.
Hint. A 2 inch nail can take some effort to penetrate, especially a knot in hardwood. Make sure you are using adequate pressure; that is the high end of the recommended pressure.
Cheers.
Dec 30, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
How to disassemble stanley bostitch sb1850bn nailer
very carefully as springs like to FLY then hide from us . but does it need disassembled . what is it not doing , or doing wrong .
Aug 31, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
Bostitch SB-1850BN. I bought a bundle of nail guns over a year ago, today I go to use this gun for the first time and just get a very poor poof of air coming out, no nail. I've tried it with pressure in...
At the end where you attach the air hose is the nailer imprinted with the words "add oil"? If so; add a few drops of oil designed for air nailers.
Also check to make sure no nails are stuck in the tip of the nailer and the return mechanism is reset.
Oct 20, 2017 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
How do I remove the trigger valve assembly?
i would just look on the box or go to the company website and ask them
Sep 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
Driver stays out after firing
You probably have a worn air seal. Or perhaps some pneumatic tool oil might do the trick. A few drops in the air outlet then bumb some nails into a piece of wood.
Apr 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
New model sb-1850bn will not operate at all. Oiled it lightly before trying to use. Air comes out around trigger.
If the air is coming out of the trigger when you try to drive a nail, most likely the driver is broken.
Bostitch nailer have a 7 year warranty on them so, take it to a Bostitch service center and have it repaired there.
Dec 16, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
My Stanley Bostitch SB-1850BN brad nailer will not sink the brad. It leaves it about an eighth of an inch above the surface. Adjusting the head using the adjustment thumbwheel does not help. Any...
You may have a broken tip or bent driver. Remove tha nails from gun and dry fire into a piece of wood. You should see a nice little indention. If you continue to hold the trigger and the nailer against wood after firing, the driver will stay in the lower position for examination. Just fire into wood and keep gun against wood while holding trigger and lean gun to side untill you see the tip. If you see broken tip or no tip order repair kit that includes driver, or driver alone from www.bostitch.com or ebay. Good luck
Sep 07, 2010 | Stanley Tools & Hardware - Others
Air Tools & Compressors Logo
264 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
