Question about HP PSC 1610 All-In-One InkJet Printer
Have hp 1610 psc all in one printer
Its the problem of the inner wheel that spins and adjusts the cartridge carriage to move fluently and bring the carriage in to center when the topo door is lifted.but that ger is either got blocked by a dust or any small piece of paper between them or any foreign object other weise the gear is cracked and cannot move properly so its creating this problem.you cannot view the gear without opening the printer.as its a black gear with a tranperant same type of wheel stuck up on the black gera its exactly on the left side of the very last of the printer.
Posted on Mar 13, 2009
The Rear Paper Exit Frame needs to be replaced. After a few years of printing, the heating element (Fuser Assembly) gets hot and it will eventually erode the plastic in this area causing the gear mounts to become brittle and literally break apart. The Rear Paper Exit Frame should be replaced and tested at a depot facility
Hope this helps
Thanks for using Fixya
Have a nice day!
http://h10025.www1.hp.com/ewfrf/wc/docum...
plz do check this hp site
Hope it helps too
Hi..I suggest you open the door on top with the power on.
The ink cartridges should move to the center. Remove and
reinstall each one separately. It is likely one isn't seated
properly.
check it out..
thank u..
Remove cartridge, make sure the protective pink tape strip has been removed, replace cart by by pushing down then sliding forward.
Let me know how it goes.
Lone99star
The sound is coming from the cartridges. The roller is sticking and causing the gears to make that noise. Removed the cartridge and manually turned the roller until it turned smoothly. (this a little hard but it worked).
Clean the encoder strip on both sides with a paper towel and water. Be cautious or you will disconnect the encoder strip from it's mounting hooks. The encoder strip is a thin plastic piece that runs horizontally the length of printer at the midpoint of the carriage.
If cleaning the encoder strip fails to solve the problem, the carriage rod probably needs to be lubricated. I believe that HP originally used grease to lubricate the rod, not just any grease but a low viscosity grease. Some people have used common silicone grease and other types and ended up making the problem worse. A reliable person on this forum has suggested Chemplex 710. You should be able to find it online.
Usually reason for noise is
A clicking (grinding) sound coming from the scanner is caused by the scanner head drive belt slipping, most likely because it cannot find it's index position (or home position). Failure to find it's index position (IP) causes the scanner head to eventually hit something solid causing the belt to slip (grind, grind). (Imagine what would happen if a scan was started from a random place.) The scanner establishes it's IP by detecting a white strip on the underside of the glass on the far right.
Why can't the scanner head find the white strip? There are several possibilities, the main electronics has failed, the scanner head has failed, the white strip it too dirty to be detected, or the scanner head bulb and/or mirror are dirty. (A dirty scanner head bulb or mirror is sort of like me trying to see through fogged glasses).
My suggestion is to clean the underside of the glass, giving particular attention to the white strip. Then clean the scanner bulb (gently) and the mirror (in the long slot) with a cotton swab sparingly moistened with Windex or similar cleaner. Doing this in addition to all of the other "magical" solutions suggested may get the scanner working.
as your issue has been resolved that's g8. Now lets work , on your printer is not printing...
refer
http://articles.techrepublic.com.com/510...
and
Uninstall all drivers.
reinstall them...
http://h10025.www1.hp.com/ewfrf/wc/siteH...
Make sure there is no signal like jamming and so on.
Thanks.
Open the catridge, clean the rollers and again try it.
Clean the rollers with a help of cotton. Might be, if the rollers are not clean , this issue might be there.
Thanks.
IF thats a paper jamming issue, follow the guidelines by Hp
Thanks.
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Check cartridge is placed properly .
Remove the cartridges from the printer, then close the cover and does the grinding sound go away? is the carriage carrier stuck?
Can you locate where the sound is coming from and what do you mean with new ink disk?
insert the cartridges back in to the printer. print self-test report.
Press setup untill print report appears then press OK
press the left or right arrow until self test report appears then press ok.
here is a guide on how to clear the paper jam
There is no heating element or fuser in a ink printer.
May 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
Jul 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
Jun 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Mar 12, 2009 | HP PSC 1610 All-In-One InkJet Printer
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
Nov 20, 2008 | HP PSC 1610v All-in-One Printer
Jun 11, 2008 | HP PSC 1610v All-in-One Printer
144 people viewed this question
Remove the cartridges from the printer, then close the cover the grinding sound does not go away? The carriage carrier is not stuck stuck?
unplugrd 30 minutes now no noise butpaper keeps going in no printing
paper now just keeps going threw no printing no jam but says paper jam
caretrages no pink tap.. papewr keeps going in no printing
sound coming from where placed new ink disks.. no sound now but paper keeps rolling threw
ink cartridges did noy move to the center
