Is there a way to get money out of the bottom of a whirlpool cabrio washer mod# WTW6400SW2
Look at the bottom of the machine...?
Is there a door or flap? that will open?
If you can't see one refer to the hand book which must have accompanied machine and try find.....'clearing debris from Pump'
Posted on Nov 18, 2015
    Scholar:
    New Friend:
  • 81 Answers
Are you hearing a rattle when the units draining causing you to assume money is in the unit? If so, fill the unit with water, take a shop vac, and suck the drain hose with it while it\'s draining. If that doesn\'t work call a tech to remove the money and inspect the pump.
Posted on Apr 28, 2013
Wtw6400sw2
I had a similiar issue last week. Had to do with drain pump parcially blocked. Search on drain issues. Coins get into the pump area and mess things up. I searched utube and found video on how to open up the washer.
Mar 29, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio fills with water but will not agitate, then it drains at end of cycle. model# wtw6400sw2
http://www.repairclinic.com/Washing-Machine-Top-Load-Whirlpool-Style-Appliance-Diagram
pray658, here is a link that might help you. if you roll your arrow/mouse down to the bottom and find the motor, to the direct upper left is a picture of the coupler. when the washer will start up and will drain the water, but not agitate. this is usually the problem.
http://www.wonderhowto.com/how-to-repair-your-washing-machine-pump-motor-and-couplers-376322/ here's a link that shows you how to change the coupler.
hope this helps.
thanks,
mike
Jul 08, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a cabrio purchased in dec of 2007.. model
Hi
Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
Apr 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I replaced the water pump on WTW6400SW2 cabrio washer twice already within the last two years. This unit is only three years old. Do you have a solution to the problem?
What was the reason. Pump Motor electrical coil failure ? or water impeller failed. If motor problem, you have to check the associated small capacitor also.Hope no water finds way to the motor.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Model WTW6400SW2 Fault F50, Motor Control board shows no sign of any damage. Could mu problem be the RPS sensor? Motor simply wont turn
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Aug 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f50
It has a faulty control board. sorry but this a bad part from the factory. There is class action lawsuit against whirlpool about it. Call and complain and then maybe they will pay to fix it.
Nov 18, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
466 people viewed this question
Top Washing Machines Experts
