Question about HP Laserjet P3015X Printer
HP Laserjet P3015 fade
Http://imgur.com/DzyQXwG Hi. I am having an issue with printing with this Laser printer. When I print, there is a noticeable fade down the right hand side of the page. I have attached an image of where I believe the issue lies. Any advice is appreciated as it is urgent that I resolve this issue. Mucho Thanks
  • HP Master
  • 1,679 Answers
This could be because of few reasons, The Ink powder is not rotating inside the drum to give you the correct output.
Remove the Toner and Shake it a bit. Try to print.
Check for Firmware update available for your printer. There are Fixes released for known issues.
Click on the link below to find solution for all Print Quality related issues for your printer
HP Laserjet Print Quality Solution
Hop this Fixes the Issue
Regards,
Sean
Posted on Apr 23, 2013
techguru005
  • 28 Answers
SOURCE: HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Posted on Feb 22, 2008
SOURCE: Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Posted on May 01, 2008
  • 138 Answers
SOURCE: Hp 2300dtn Poor quality printing
Well lets start with DISREGARD ALL THE ABOVE BULL in the above brainless clarification request first noted. Here's a little good advice for you from a 14 year veteran printer tech.
Lets start with the cheapest and easiest moving to the more difficult or more expensive. Your problem can be caused by a few differnt things.
Print a configuration page (on the printer menu press check button, scroll to info menu, press check, scroll to print configuration, press check. Once you have the look for the page count on the page.
Try fresh good paper from a sealed ****. If your paper has picked up moisture this will show up as light or uneven print.
Next if the printer is over 100K page count, replace the transfer roller (foam roller inside printer under the toner cartridge). Lets try cleaning it first if your under 100K or to see if it improves at all. Any improvement will verify the transfer roller as bad. Review the photo below as it shows the transfer roller end inside the printer. The screwdriver is showing where the release white clips are (two). Press the tabs and lift the left side. The right will come out of the hole socket on its own but note where the hole on the right is for replacement. Try not handling the roller with your bare hands any more than you must as oil from your hands can cause slight imaging defects if your hands are sweaty or damp.
Using a clean rag (like t-shirt material) dampened (not soaking) with 99% alcohol (not 70%) lets clean the roller. Gently but firmly scrub the talc and paper dust buil-up from the roller. Once you've removed the build up it should return to a dark grey color. Let the 99% alcohol dry (5 minutes or so)and reinstall.
Try printing again. If the problem is solved your done. If not and it has improved, you will need a new transfer roller. They are available on Ebay much cheaper than from a dealer. The part number to search for is RM1-0343. Here's a link to ebay for one at around $20.00 landed.
http://cgi.ebay.com/LJ-2300-Transfer-Roller-New-OEM-RM1-0343-Unopened_W0QQitemZ270247145853QQcmdZViewItem?_trksid=p3286.m20.l1116
If the problem is the same, your problem is more than likely a dirty laser scanner lense. You'll need to remove the covers from the printer to accomplish this. The laser scanner can be located under the top cover. It's the larger black box on the top side of the printer. Once the scanner has been located, remove the top cover. DO NOT TOUCH THE MULTI SIDED SPINNING MIRROR TO THE REAR OF THE SCANNER. You will be cleaning the clear lenses and mirror towards the front. You clean this gently with a CLEAN and DRY Q-tip. Use a few Q-tips rather than re-applying a dirty one. Heck they are cheap!
Re-assemble the printer and try printing again. One of the steps above should resolve your issue. I am enclosing a link to a free service manual for your printer to help you through the disassembly and in the rare case that your issue remains.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope this helps you a lot more than the first response you receved. If so rate me with a FIXYA!
Thanks.
Posted on Oct 02, 2008
patemi
  • 366 Answers
SOURCE: HP 2420 Faded Print outs
Check (and remove) the "economode"in "Printer Preferences" (right click on Printer applet) normally in "Paper /quality" Tab
Posted on Jan 03, 2009
till death
  • 6 Answers
SOURCE: printing fades towards the right hand side of the page. There is no toner leakage.
first u change toner
if problem presist
replace fuser assembly
Posted on May 04, 2009
Laserjet P3015 displaying error code 59.30 how to resolve
this issue is comes from data transfer error,please delete all print command
Jul 28, 2016 | HP LaserJet Enterprise P3015d BW laser...
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
LaserJet P3015. Why is it printing dark background?
Hi Boateng Samuel,
I would be happy to help you with your P3015. Although the enterprise printer models are out of my support scope, I was able to find you the appropriate document specific to print quality. Please use the following document to troubleshoot the issue:
HP LaserJet P3015 Printer Series Solving Print Quality Problems
Best of luck, I hope this helps.
I work on behalf of HP.
Jul 17, 2015 | HP Office Equipment & Supplies
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
My HP 3015P will no longer print PDF files. This is a new issue. Anyone have a solution?
I'm having the same problem with three networked P3015 printers on a Windows 2003 server. They stopped printing PDF files last week. The universal PS driver from HP works, but it's a pretty ugly solution. I'd like to know why the PCL driver just stopped working.
Btw, we're printing from Acrobat 9.4.2. Word, Excel, and other office printing is fine still.
Feb 17, 2011 | HP P3015 Laser Printer
51.10 ERROR
i cant print my document my hp laserjet p3015 print display error message 51.10. please slove this imdy.
Dec 13, 2010 | HP P3015 Laser Printer
HP Laserjet P3015X Printer Logo
370 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
