Question about Transcend T.sonic MP330 MP3 Player
Please help, My Transcend MP330 player does not appear in my computer any more.
Initially, it was appearing in My computer as a storage device. It is not detected anymore and there are no error or any kind of information appearing.
My transcend mp 3 player does not appear in my computer any mo re its only getting charge
Posted on Jul 03, 2013
  • 57 Answers
SOURCE: can,t detect my transcend 2gb flashjet
The issue that you are experiencing may be caused due to unexpected removal of the drive from the computer.
However, please follow the below given instructions to resolve the issue.
If you are using Windows Operating system, please follow the below given instructions:
1. Right click on My Computer icon which is on the computer desktop.
2. Go to Properties.
3. Click on Hardware Tab.
4. Then click on Device Manager.
5. Click on the + Sign beside Universal Serial Bus Controllers.
6. Find USB Composite Device entry from the list.
7. Right click on each USB Composite Device Entries and choose the options Delete/Uninstall.
NOTE: An error message may appear. Click on OK/Continue.
8. Unplug and replug the USB device/Flashjet Memory device.
This should resolve the issue.
Regards,
Lawrence
Posted on May 11, 2008
SOURCE: trnascen T.sonic player detected but cannot be opened in computer
I Have a t.sonic 610 mp3 and i dont know how to delete songs can u help?
Posted on Jan 10, 2009
SOURCE: File format error - Transcend T.sonic 610(1gb)
This can happen if you try formatting it from XP or any other windows OS. Now that the memory is already lost. I don't think there's anything much you can do. But try formatting it from DOS or cmd prompt. I think it can solve your problem.
Posted on Mar 23, 2009
SOURCE: please help to format my mp3 player
plz check the reset button on your mp3 player if ypu dont find the button, your player must be affected with virus so, kindly check with your dealer for replacement.. plz kindly rate me
Posted on Jun 27, 2009
anujtaluka
  • 392 Answers
SOURCE: Transcend T.sonic 840 doesnt start
1.download the appropriate firmware from here 2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "volume -" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
Posted on Sep 06, 2009
Usb removable disk is suddenly showing as local disk
Check that the safety switch is not on the USB. Some of them have a simple on off switch that gets turned off. I have made that mistake myself even knowing they are there. If there is not one of these switches I would try the device in another computer and see if it comes up the same way again.
Feb 04, 2014 | Transcend 640GB Transcend StoreJet 25D3...
My transcend MP330 is not gettin recognized by the computer..
1) Turn on your mp3
2) go 2 settings>MTP thn select MTP
3) connect 2 a pc
then you'll see it as a portable device
4) FORMAT IT
5) go 2 settings>MTP thn select USB [on ur mp330]
Jul 06, 2012 | Transcend T.sonic MP330 MP3 Player
Water inside the player now not working
If drying out the player in a warm spot for several days and if it still does not work, then most likely the player is damaged beyond repair.
May 07, 2012 | Transcend T.sonic MP330 MP3 Player
I pod doesnt shows any memory in it .when connected to pc the device cant be detected.it may be some software problem we think so how could we solve this..
You can repair your player. Visit Transcend website and download mp330 firmware via this link:
http://www.transcend-info.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=262&ItemID=TS8GMP330&Controller=#2
This file is a .zip file, you should extract it and read the pdf document. The procedure is described detailed and not complicated. In the .zip you can find the executable firmware upgrade file too.
Thanks.
gylacz
Sep 14, 2011 | Transcend T.sonic MP330 MP3 Player
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
USB Drive not detected by computer
Try to install latest chipset drivers for your motherboard. If you don't know what motherboard you have, you can download Everest and it'll give you all needed info.
If after install you still have this problem tell me, and we'll try to find a solution.
Feb 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Can,t detect my transcend 2gb flashjet
Regards,
Lawrence
May 11, 2008 | Transcend T.sonic 612 MP3 Player
Transcend T.sonic MP330 MP3 Player Logo
354 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
