Question about Electronics - Others
Car won't start
It's probably dead/shorted/bad...try testing it at Sears...Wherever...
Posted on Apr 22, 2013
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
What's your problem?2001 Bentley arnage. Car Won't start.
Know a fellow with a Bentlet He basically has to keep battery on atricle charger most of the time or it won't start. You don't always get what you pay for!
Aug 05, 2012 | 2001 Bentley Arnage
My car won't start it kicks over but won't start
It has to be one of only 2 problems. No spark or no gas. Check both to make sure they are being supplied.
Jun 03, 2012 | 1996 Ford Contour
2002 saturn sl won't start, turn over but won't start
If the engine fires up for a second or two with starting fluid then the fuel pump is weak.I would check the fuel pressure and if its not within the specs then replace the pump and filter.
Jan 26, 2012 | 2002 Saturn Sl
The car sat up awhile. The battery died. We replaced the battery but the car still won't start. Everything comes on. The starter was tested and it was fine. What is the problem?
THERE ARE MANY POSSIBLE CONDITIONS THAT COULD PREVENT YOURCAR FROM STARTING. 1. NUTERAL SAFETY SWITCH IF THE CAR HAS AN AUTOMATICTRANSMISSION. 2. CLUTCH POSITION SWITCH IF THE CAR HAS A MANUAL TRANSMISSION.3. BRAKE PEDAL SWITCH. MANY NEWER VEHICLES HAVE A SWITCH ON THE BRAKE PEDAL ANDIF THE PEDAL IS NOT DEPRESSED WHILE TRYING TO START THE CAR, THE CAR WON'TSTART. ANOTHER POSSIBLILITY IS THE SECURITY SYSTEM. DOES THE CAR HAVE ASECURITY CHIP IN THE KEY? THESE ARE SOME OF THE MOST COMMON REASONS THAT A CARWON'T START FOR NO APPARENT REASON. HOPE THIS HELPS.
Aug 18, 2011 | 1999 Mitsubishi Montero Sport
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
