Question about Garmin nuvi GPS
Will my Garmin Nuvi 40 work with a 24 volt supply ?
Garmin Nuvi 40 , will it take 24 volts through the in car power lead supplied when new ?
  • Garmin Master
  • 2,130 Answers
If you are using a standard Garmin car charger, you can connect the charger to a DC power source that can provide between +10VDC to +30VDC. The charger produces +5VDC to power the Nuvi. This can be verified on the charger label.
You can NOT connect any voltage higher than +5VDC directly to the Nuvi.
Posted on Apr 24, 2013
hydetech
  • 113 Answers
SOURCE: garmin c320
yes
320 specs
Posted on Oct 26, 2007
  • 9 Answers
SOURCE: Nuvi 200W GPS power supply will not stay plugged in
hpd367 - If your Garmin has died within a year then call them for an RMA number and they will repair/replace it.
Tel 0808 238 0000
Moscow Nell - I had the same problem and got an adaptor from Halfords for about £5.
Posted on Apr 04, 2008
sharcnet
  • 2130 Answers
SOURCE: Operating Manual for Garmin nuvi 760
Please try this link to download the manual for the 760 in the language of your choice.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00657-10&cID=137&pID=10624
- Jim
Posted on Jan 27, 2009
  • 1514 Answers
SOURCE: Garmin Nuvi 250 - When I attach the 12 volt
The problem is with the socket at the back of the satnav where you plug in the mini USB plug of the power cord. As the socket wears it feels as if the plug is in fully when it's not. Push the plug in further and the problem should be solved.
Posted on Sep 24, 2010
  • 1514 Answers
SOURCE: Car power supply for Garmin
I assume you have checked the cigarette lighter to be sure it's working.
The most likely problem is the fuse in the power cord/charger. The plug which goes into the cigarette lighter socket has a ring at the end of it. Unscrew the ring, taking care not to lose any small parts, and it comes apart. Replace the fuse and it should be ok.
Posted on Dec 26, 2010
Atx motherboard wiring diagram
For the power cables from the Power Supply? Or Power Supply, and Front Panel header on the motherboard?
For both of these you need to state the computer manufacturer name, and Model Number.
Post back in a Comment.
If you just wish a generic, one-size-fits-all explanation;
A) 20 or 24-pin ATX main power cable.
The older computers use a 20-pin ATX main power cable. As computers needed more power to the motherboard, the 24-pin ATX main power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll the page down for info on the 24-pin ATX main power cable.
[ Much older motherboards (AT) used two main power cables. { In the link - Original PC main power cables} ]
B) 4-pin ATX +12 Volt power cable.
Was brought out because Processors needed more power, than the 24-pin ATX main power cable feeding the motherboard, could deliver.
Power for the Processor,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) 4-pin standard Peripheral power cable
Commonly misnomered as 'Molex'.
Molex was a model name given by the first manufacturer, of this design of power cable connector.
The name stuck. Kind of like referring to an adjustable open-end wrench as a Crescent wrench.
It is also referred to as a 4-pin Standard Peripheral power cable, because there are two styles of 4-pin Peripheral power cables.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Generally used for IDE (PATA) harddrives, and IDE optical drives.
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used it for power to the Floppy Drive. It's generally used now to provide power for a Card Reader.
Note that both types of connectors use the same power wires, and 2 ground wires.
Yellow is 12 Volts
Red is 5 Volts
Black is Ground
[ Also, in the ATX main power cable:
Orange is 3.3 Volts, the Green wire is the Soft Power On wire. Abbreviated as PS_ON.
Power Supply plugged into power, the Soft Power On wire is briefly touched to ANY Ground wire. This is bypassing the Power On switch.
If the computer (Power Supply) comes on, you have a bad Power On switch.
IF the computer (Power Supply) does NOT come on, you have a bad Power Supply ]
(ALL Black wires are Ground wires. They all lead back to one central Ground point.
ALL power wires lead back to one point in the power supply, for EACH power wire.
The 12 Volt power wires, (Yellow), all lead back to one point in the Power Supply.
This is the 12 Volt power rail.
The 5 Volt power wires, (Red), all lead back to one point in the Power Supply.
This is the 5 Volt power rail.
The 3.3 Volt power wires, (Orange), all lead back to one point in the Power Supply.
This is the 3.3 Volt power rail ]
D) SATA power cable
15-pin power cable for SATA harddrives, and SATA optical drives,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ The smaller 7-pin SATA connector is the interface cable, or data cable.
IF, you have a SATA harddrive that has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
It will burn out the harddrive if you use both. It may not do it right away, but eventually it will.
I have had people state over the years, that they were using both power cables. Came back two months later to tell me their harddrives had burned out ]
More to follow in a Comment.
Regards,
joecoolvette
Sep 30, 2011 | Computers & Internet
Is this unit avaliable to be used on 12 volt and 24 volt vehicles
Yes as long as you use the original garmin charger that comes with it. The garmin charger steps down either 12 or 24 volts to match the 5 Volt required input voltage of the satnav.
May 05, 2011 | Garmin nuvi 250W GPS Receiver
How to cargs battery
No you don't unless of course your power supply does not work unless the key is on, otherwise plug one end into the 12 volt supply, the other end into the gps and happy charging.
Apr 02, 2010 | Garmin nuvi 200W GPS Receiver
A samsung 40'' mainboard BN41-00879A no video-no sound I have just bought a new mainboard ------Is there any ajustment on a new board.? or have I got a doa board??
SOUNDS LIKE YOU NEEDED AN INVERTER BOARD OR POWER SUPPLY INSTEAD OF A MAIN BOARD, UNPLUG THE CABLE FROM THE INVERTER BOARD AND SEE IF THE 24 VOLT LINE COMES UP, IF THE 24 VOLTS IS THERE AFTER YOU UNPLUG IT, THEN YOU NED A NEW PANEL, IF THE INVERTER BOARD IS NOT REPLACEABLE
Dec 30, 2009 | Samsung LE40M91B 40 in. LCD TV
Unable to use my Nuvi 200 on external power
My origional car power lead had a broken 5 volt line and the supposed replacement item did not have a pull down resistor from pin 4 tl pin 5 ( ground ) As soon as I rectified this the unit worked as advertised.
Aug 27, 2009 | Garmin nuvi® 200 Car GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Adding trailerbrakes to a 24 volt truck
Are your electric brakes rated for 12 volt or 24 volt, that is the question. YOu have to supply the voltage at whatever the brakes are rated for.
Apr 15, 2009 | IBM LENOVO 24V POWER SUPPLY 42L0085 Power...
The end of my 12 volt power supply cord was lost.
You might be able to use the parts from an old cell phone adaptor. Have you tried that?
If not don't mess with any off brand adaptor. Get another one from Garmin at their website Garmin .com
Jan 22, 2009 | Garmin nuvi 260W GPS Receiver
LCD tv issue
at error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Aug 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tel 0808 238 0000
Mar 27, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
265 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
