Question about Salton Melitta MEK17W Electric Kettle
Scale filter for Melitta Express Kettle
Would like availability and price for replacement scale filters for Melitta MEK17W cordless electric tea kettle
  • Corey Knoettgen
    Corey Knoettgen May 11, 2010
    I would call Salton directly - the part costs around $16.99
  • 16 Answers
SOURCE: Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
Posted on Jul 26, 2010
  • 4102 Answers
SOURCE: sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Posted on Nov 17, 2007
chie-chie
  • 98 Answers
SOURCE: brewing loose leaf
yes
Posted on Feb 06, 2008
SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Posted on Sep 15, 2008
  • 9 Answers
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
Posted on May 23, 2010
I need a spout filter, part # 31036 for my express kettle MEK 17W
  1. New: Melitta Kettle Parts - buycheapr.com‎
    Admelitta-kettle-parts.buycheapr.com/‎Melitta coffee maker parts: BuyCheapr.com
  2. Melitta Kettle Parts - bizrate.com‎
    Adwww.bizrate.com/Melitta+Kettle+PartsVacuums
  3. Microwave Ovens
  4. Coffee Makers
  5. Heaters
  6. Melitta Cordless Kettle - Amazon.com‎
    Adwww.amazon.com/kitchen‎rating for amazon.com
    Up to 50% off Melitta cordless kettle Free Shipping on Qualified Orders.
    Ratings:Website 10/10 - Shipping 10/10 - Selection 10/10
Search Results
    Need replacement filter for Melitta Express Cordless Kettle ...
    www.fixya.com/support/t6685355-need_replacement_filter_melitta
    Nov 3, 2010 - Need replacement filter for Melitta Express Cordless Kettle Model MEK17W - Salton Melitta MEK17W Electric Kettle question. ... Question about SaltonMelitta MEK17W Electric Kettle ... Video; Photos; Link; Replacement Parts.
Jan 06, 2016 | Kitchen Appliances - Others
Filter for salton kettle
The filter for a Melitta MEK17W or Toastmaster TEK17W (identical kettles)are the same.
If you still have the old original filter, here is the link to an inexpensive and permanent repair option using stainless mesh:
Apr 07, 2014 | Salton Melitta MEK17W Electric Kettle
I need to buy filters for the spout. Where in the San Jose area are they available?? Melitta MEK 17W electric kettle.
If you can no longer find this scale filter online or from the manufacturer, then you can still repair your original one and make it better than new! This fix has worked perfectly on my MEK17W kettle and it turns off properly when the water boils.
Buy a piece of 3"x3" 100 mesh (150 micron, must be stainless) on Ebay - under $3 inc shipping. Carefully cut the old plastic mesh out of the original filter frame with an exacto blade and very lightly sandpaper the triangular face of the plastic frame that faces into the kettle. Then temporarily hold the stainless mesh to this inside face of the filter frame with a couple of clothes pegs and use a pencil to mark the
triangular outline of the mesh so that it will fit flush against the plastic and also be no wider than the frame. Carefully cut the triangle of mesh to size with scissors. Thoroughly mix up a small portion of 5-minute 2-part epoxy glue (Loctite or JBWeld) with a thin wooden coffee stir stick and apply just a smear of glue to the frame. As soon as the glue starts to get tacky, gently fit the mesh to the frame and clip it there lightly with 5 plastic clothes pegs, 2 on each side and 1 at the bottom. To ensure their release, you can first wipe the pegs (where they pinch together) with the faintest skim of Vaseline or sewing oil. Let the assembly set for 24 hours and then carefully ease off the pegs. You will now have a filter that will last longer than the kettle.
Oct 09, 2011 | Salton Melitta MEK17W Electric Kettle
Where can I buy a new scale filter for Melita kettle MK816L I live in the Pickering Ontario area. Thank you
Hi supergran27 :-),
Here's the phone number and location of Salton agents nearest to you.
Pickering Town Centre
1355 Kingston Rd. #70
Pickering, ON
L1V 1B8
Phone: (905) 421-9864
For other agents in Ontario region, click on the link below.
http://www.salton.com/customer-care
Best wishes,
Graeme.
Mar 23, 2011 | Salton Melitta MEK17W Electric Kettle
Hi, your filters can be bought from amazon. here: Amazon com melitta filters I hope this was helpful. cheers
Nov 03, 2010 | Salton Melitta MEK17W Electric Kettle
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
May 06, 2010 | Salton Melitta MEK17W Electric Kettle
The spout filter in my Toastmaster TEK17W kettle has torn. Where can I get a replacement
Aug 13, 2009 | Toastmaster (TMHP2) Electric Kettle
Salton Melitta MEK17W Electric Kettle Logo
1,373 people viewed this question
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
tsalagi152
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
