Question about Zebra Office Equipment & Supplies
Zebra zm400 CUTTER JAM problem? - Zebra Office Equipment & Supplies
ashish13
  • 75 Answers
SOURCE: Some noise comes when printing
Here is the link for the Service Manual required which i uploaded for you... hope this resolves your issue...
http://www.adrive.com/home/downloadfile/136030403
Posted on Feb 12, 2009
SOURCE: my zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Posted on May 20, 2009
  • 35 Answers
SOURCE: zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Posted on Feb 16, 2010
ozztech
  • 285 Answers
SOURCE: como cambiar ip de zebra zm400 desde el panel
you need to connect with some network to the ip adress coming on the setings, if you dont connect with network, that function not apper.
If connect, you be aple to change to IP estactic and the Gateway and the subnet mask.
Dont forget to save.
Posted on Nov 13, 2010
ozztech
  • 285 Answers
SOURCE: Printing and counting problem with Zebra
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
Posted on Mar 26, 2011
Printer ready, Feed option does not working. Other power supply settings printer working properly.
the problem may be in the control panel button itself. the feed button aways works, no adjustments necessary. It's main purpose is to advance the labels.
Jun 27, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Feed option not working but printer ready.
Dear jafar,
just first you conform there is no paper jams in your printer then only i will tell it is motor issue///
Jun 18, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Zebra 110xi4 labels jam going into the cutter
This is usually related to the setup of the printer. Check that there is no backfeed set up, and that the settings are on for calibration on head close.
Oct 10, 2012 | Zebra 110Xi4 203DPI 10100 CUTTER W TRAY...
Zm400 label jam
Hi
Do not use a tool you may damage the printhead which will cost ofver 300 pounds to replace. First get what you can off with your fingers, then use IPA swabs or cotton cloth soaked with white spirit to gently and patiently remove the remains of the label and any adhesive residue.
Regards
Rob
Plain, Printed and Barcode Labels
May 11, 2012 | Zebra ZM400 Thermal Label Printer -...
Zebra printer drops network
i hadthe same issue with all my zm400's, but not my zm4 plus's. zebra gives you the run around when contact their technical support.
I tried every setting there was, ended up get rid of the zm400's, they are a piece of C#@P
Feb 03, 2012 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Error in position of the output for ZM400
this is usually caused by a pressure imbalance across the printhead. Check the printhead pressure adjust dials located on top of the printhead. You might find that the left side has more down pressure than the right side causing the ribbon to move to the right.
Hope that helps !
Apr 09, 2010 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Zebra zm400 turn printed info 180 degrees
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Open Questions:
1,082 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
