Question about DCS RGU-366-N 36” professional 6 burner gas range
DCS 366 Oven Sputters Continuously
My oven works just fine however, it has started making a rumbling/sputtering sound. The sound is pretty continuous. Any ideas? This model is gas.
5 Suggested Answers
SOURCE: hi, we have a dcs 366 gas range. the pilot light
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Posted on Mar 15, 2009
SOURCE: DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Posted on Aug 10, 2009
  • 85 Answers
SOURCE: DCS RGS 366 range, oven will not do anything when I turn it on
Sounds like the electronic ignitor has gone bad. Here is DCS contact info, they should be able to direct you to a reliable service provider:
contact DCS Customer Service at (888) 281-5698. Before you call, please have the
following information ready:
 Model Number (located on rating plate backside of kickpanel).
 Serial Number
 Date of installation
 A brief description of the problem
Your satisfaction is of the utmost importance to us. If a problem cannot be resolved to your satisfaction,
please write, fax, or email us at:
Write:
DCS
Attention: Consumer Relations
5800 Skylab Road
Huntington Beach, CA 92647
Fax us at: (714) 372-7004
email: support@dcsappliances.com
Posted on Oct 17, 2009
  • 7 Answers
SOURCE: Very low rumble when oven is on, more noticable as oven warms up.
please contact me at verng@craneengineering.com for a solution to your range problem
Posted on Nov 06, 2009
Why doesn't oven work?
Give the repair man the opportunity to make the oven work instead of charging you for parts that probably did not need to be replaced.
Dec 01, 2015 | DCS RGS-366 Professional Gas Kitchen Range
My oven won't light.
Does it glow real bright like orange or just red. Because if it's not real bright orange, the ignighter could be bad. The oven will not light if the ignighter is not hot enough.
Sep 22, 2014 | DCS RGT-366-L
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Mar 24, 2010 | New World G60m Gas Single Oven
DCS 5 burner 30" oven makes loud noises as if starved for fuel
Hi; Is the oven run with LP or NAT gas. Sounds like a regulator problem not letting enough gas through. Also is this a comercial unit. If so when was the last time all burners and pilot orafices were cleaned out. The burner tubes have a air vent cut into the burner at the orafice. Make sure no debris have covered these airways.And lastly how old are the thermocouples and are they secure to the gas valves and have a good pilot flame on them...
alpharome416
Feb 23, 2010 | Ovens
 Serial Number
Write:
DCS
5800 Skylab Road
Oct 16, 2009 | DCS RGS-366 Professional Gas Kitchen Range
How do I get the door back on my DCS 366? Overzealous cleaning dislodged the "hooks".
ther should be two dogs that slip out of position
they are on the oven
you will need to pull the door slide down,, slip a small nail in the hole do this on both sides
the slide the doo on
once you pull the pins out the dooor should be locked in place
Oct 03, 2009 | DCS RGS-366 Professional Gas Kitchen Range
Sounds like an built-in exhaust fan going bad. Bearings most likely.
Jul 08, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
Mar 15, 2009 | DCS Kitchen Ranges
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Broiler not working, Oven OK
We have a DCS RG-366 SS L, a 36" gas range and the igniter went out. You could smell gas and the igniter would glow red - but no fire across the broiler.
There is a place in Michigan called RepairClinic.com. We bought a replacement igniter from them and it works like a charm. It was $53 (we live close by and didn't have to have it shipped).
The item number (from the invoice) is 1191 and the box the igniter came in looks like it is manufactured by FSP, code 082005, and there is a larger number on the box that says 786324 IGNTR-OVEN.
Hope this helps.
Sep 13, 2008 | DCS RGS-305 Professional Gas Kitchen Range
DCS RGU-366-N 36” professional 6 burner gas range Logo
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
