Question about Toshiba TLP-XD2000U Mobile Projector
Please Help me How to reset the timer for the Toshiba TLP-XD2000
I recently replace the bulb for TLP-XD2000.
Thanks-IceBox
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Aug 04, 2014 | Toshiba TLP560 Projector Lamp 195Watt...
Reset lamp hours toshiba tlp xd2000
"menu""input""enter" hold in the on position
Mar 02, 2012 | Toshiba TLP-XD2000U Mobile Projector
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
Reset lamp timer
If you go into the info menu you should see lamp hour meter, should be option there to reset it.
only do so if you have put in a new bulb as bulbs can explode if they go over the hour usage time.
Many thanks
Feb 15, 2011 | Toshiba TLP S30 Multimedia Projector
How to reset the lamp counter for Toshiba ELP-X3000 model after repalcing the lamp
Hi
Go into the menu.
GOto status in there you should find the lamp timer reset.
Many thanks
Feb 15, 2011 | Toshiba TLP-X3000 LCD Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Toshiba TLP-XD2000U Mobile Projector Logo
320 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
