Question about NoiseHush NS560 Clip-on Bluetooth Stereo Headset - White Original OEM
How do you charge the noisehush ns560 - NoiseHush NS560 Clip-on Bluetooth Stereo Headset - White Original OEM
Over head mic came out of slot
Hello, Naz.
The same thing happened to mime.
There is a plastic notch that prevents the metal arc piece (which slides into the plastic housing to adjust the length of the head rest end) that probably broke.
What I did to fix mine is to get a little zip tight used to wrap cables together and used it near the end of the plastic housing to hold the metal piece. You should tie is as hard as you can (BUT WITH THE META PLACED INSERTED - other wise you can break the plastic housing), and cut the strip with a scissor or cutter plier. In fact, in mine, I can even slide and adjust the metal band as I wish and resume normal operation of the headset without any problems.
I hope it will help your.
RC
Sep 06, 2014 | Naztech Noisehush N700m Over-the-Head...
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
My bluetooth light shines blue on my cellphone,the phone says bluetooth is connected,but the headset does not appear to function,,,,it worked an hour ago just fine ,,,,i could not find any instructions for...
the bluetooth device battery is it charged and is it ok,if you live your phone very there is a distance limit then it goes on standby for a limited period then it automatically switchies off
Jan 20, 2014 | Naztech Noisehush N700 OverHead Bluetooth...
Can u plz give me a free unlock code for my e739 lgmytouch
Hello My Dear Friend:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 09, 2013 | NoiseHush Lg Compatible Mytouch E739 N800...
What is the pairing number?
My instruction manual said if it asked for a pairing number to enter, "0000" That is 4 zeros. Hope it helps.
Jul 06, 2011 | Naztech Noisehush N700 OverHead Bluetooth...
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 | Cell Phones
What is this vendosupport.com?? Why is money transacted to this site without my knowledge??
mony tarnsactions with out my knowledge in vendosupport.com i went to cansel the taransaction
May 04, 2011 | Computers & Internet
I lost my manual and don't know how to pair the headset to a new phone
Turn unit on - hold function button for 10 seconds
Led should flash red -blue-red-blue ...
on your moble device go into the search function
passcode 0000 (4 zeros)
if successful only the blue led should be on
Apr 07, 2011 | Naztech Noisehush N700 OverHead Bluetooth...
NoiseHush NS560 Clip-on Bluetooth Stereo Headset - White Original OEM Logo
163 people viewed this question
Top NoiseHush Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a NoiseHush Radio Communication Expert? Answer questions, earn points and help others
