My laptop memory card slot say this device is write protected.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
On most cards there is a tab you need to move to enable the computer to write to the card, this protects other info on the card, look for the tab and switch to open
Posted on Apr 24, 2013
suvishal
SOURCE: Memory card not recognized
watis the operating system ur using???????its better to use vista rather than xp on satellite........when did u buy that laptop..
if u use vista drivers vll b detected xp cannnot detect...this is the main  problem
Posted on Nov 02, 2007
  • 4 Answers
SOURCE: Can only find one memory slot/bay for my Inspiron 1720, correct?
Dimm B is under the cover from the back of the computer
Dimm A is under the keyboard, remove the hinge cover then the keyboard.
Posted on Mar 08, 2009
  • 489 Answers
SOURCE: can't locate memory card slot for my cell phone's sandisk thing
This model does not have a memory card reader installed. If you need to access memory cards, you will need to obtain a PC Card for that purpose or a USB memory card reader that supports the card format you wish to use.
Posted on May 26, 2009
shynysaxena
  • 166 Answers
SOURCE: How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
lserni
  • 466 Answers
SOURCE: How to eject RS-MMC card from card reader slot in acer 4736 ?
Usually there is a spring latch: press the card deeper into the PC, and it will click out.
If it doesn't, the spring may not have engaged, or may be broken. To extract a stubborn memory card, it usually has two grooves on the top and bottom to allow extraction by hand using your fingernails. Some cards don't have the grooves though, and for those you can use a pair of tweezers, or use two strong sewing needles as "prybars" from the left and right side of the card simultaneously.
If it still doesn't work, something went really really wrong with the latch and you'd best send it to assistance. As an extreme resort ONLY, wet the short side of an unfolded paper clip with Loctite glue, and taking the utmost care not to touch ANYTHING but the short side of the memory card, stick it to the memory card's short side. The traction made available by half an inch of Loctite on a steel paper clip should be enough to tear the memory card apart, let alone extract it. But if you need that much force, chances are that you'll end up destroying the reader: that's why I suggest going to the assistance if things come to that.
Posted on Oct 29, 2009
My memory card protective cover is stuck inside the memory card slot. how do I remove it out? my laptop is under warranty & you have no service stations in goa.
Hi,No need to worry,i'll ask this can you see the Adapter when you look into the memory card slot?if you do,you will need this item:- Forceps or Tweezers use either of these insert it into the slot make sure you dont push the adapter inside grab the adapter and pull to remove.
Jan 02, 2011 | Acer Computers & Internet
I have a compaq nc6220. When I insert a memory
if ur slot is not working then i think ur adapter of memory card is write protected or if u want to use ur memory card with ur lappy so please i advice u 2 purchase card reader and then use ur M.C coz the usb slots are working efficiently with memory card........ for more help mail me at vicky.akon11@gmail.com thank u sir
Mar 24, 2010 | HP Compaq nc6220 Notebook
Compaq 6910p Notebook does not recognize a SD-MMC memory card when inserted into the slot. The memory card is fine, as I can access it using a USB card reader, but it is not recogized in the Notebook's...
If the memory card is recognized and readable in a USB card reader, the memory card is fine. If the 6910 does not recognize the memory card, either the card is not properly seated in the 6910 card reader slot, the card slot is not connected to the main board of the 6910 or you need a DIFFERENT device driver for the 6910.
Nov 25, 2009 | Compaq Hewlett Packard 6910p Notebook
I have a Gateway M-7315u laptop. I don't have a book on it. I know what the SD slot does, but what is the slot below it for? What is MMC/MS/xD?
The other slot below the SD slot is a memory card reader for other types of flash memory cards that are used in various digital devices.
Nov 20, 2009 | Gateway M-7315U Notebook
I have an Acer 9300WSMI laptop. Does it have a card reader and if so where is it? Thanks Fitzy
SD card slot is on the right hand side of the laptop (with it facing towards you) at the front.
SD card slot is #2
Regards.
Jul 28, 2009 | Acer Computers & Internet
Using multiple card slot
There will be a slot, the size of the SD memory card on the front edge or side of the laptop. The slot will be the same size as the slots in an USB memory card reader.
You can download a manual from the Toshiba WEB site.
You can download any/all the Windows XP or Vista device drivers and manual for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers and manual.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 14, 2009 | Toshiba Satellite Pro L300 Notebook
Memory stick photos to laptop
Connect a card reader and insert the memory card to this card reader and you can transfer the pictures to your computer. Now most of the card readers have slots to insert all types of memory cards, you can have any card reader from a local electronic shop.
Mar 25, 2009 | HP Pavilion Laptop RM-70 Notebook
PCMICA/USB 2.0 not recognising usb devices
if it works on the onboard usb.
Theres a chance that either the pcmcia slot drivers are incorrect, or the actual slot is faulty.
Try it in another slot, if you have 1.
update any onboard device drivers. if applicable. try the card in a different laptop. to eliminate the card. alternatively, try a different card in the slot. wifi card et,c.
Mike @ compurepair.
Dec 16, 2008 | Compaq Armada M700 Notebook
Try to put your sd card to the slot, and check device manager.
check if there is yellow question mark on the device manager.
if it is, it's driver problem, just update the driver.
if not, try with another sd card and if this still not working, it's your sd card slot has problem.
Mar 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory StickĀ® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
